IP Routing & IP Multicast Commands are not available on WS-C3750X-48P-L
Mohammed Moqbel
I got two switches smiley:
WS-C3750X-48P-L
WS-C3750X-24P-S
both are running on 12.2(55)SE5  but I couldn't find both ip routing & ip multicast on WS-C3750X-48P-L
I have upgarde WS-C3750X-48P-L to the lastest version 15.2.1E2 and I got only ip routing command only.
Below outputs of show version & ip ? commands generated on both switches when running 12.2(55)SE5
Thanks in advance.
WS-C3750X-48P-L
FDR_SW#show  version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
FDR_SW uptime is 10 minutes
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-48P (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1649X0WP
Last reset from power-on
22 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 44:03:A7:7E:8D:00
Motherboard assembly number     : 73-12553-08
Motherboard serial number       : FDO16490CEV
Model revision number           : K0
Motherboard revision number     : A0
Model number                    : WS-C3750X-48P-L
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO164901DB
System serial number            : FDO1649X0WP
Top Assembly Part Number        : 800-31324-07
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMJZ00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    2 54    WS-C3750X-48P      12.2(55)SE5           C3750E-UNIVERSALK9-M
Configuration register is 0xF
FDR_SW(config)#sh ip ?
Global IP configuration subcommands:
  access-list           Named access-list
  accounting-list       Select hosts for which IP accounting information is kept
  accounting-threshold  Sets the maximum number of accounting entries
  accounting-transits   Sets the maximum number of transit entries
  address-pool          Specify default IP address pooling mechanism
  admission             Network Admission Control (NAC)
  alias                 Alias an IP address to a TCP port
  arp                   IP ARP global configuration
  arp                   IP Arp features
  auth-proxy            Authentication Proxy
  default-gateway       Specify default gateway (if not routing IP)
  device                Device tracking
  dhcp                  Configure DHCP server and relay parameters
  dhcp-client           Configure parameters for DHCP client operation
  dhcp-server           Specify address of DHCP server to use
  domain                IP DNS Resolver
  domain-list           Domain name to complete unqualified host names.
  domain-lookup         Enable IP Domain Name System hostname translation
  domain-name           Define the default domain name
  finger                finger server
  ftp                   FTP configuration commands
  gdp                   Router discovery mechanism
  gratuitous-arps       Generate gratuitous ARPs for PPP/SLIP peer addresses
  host                  Add an entry to the ip hostname table
  host-routing          Enable host-based routing (proxy ARP and redirect)
  hp-host               Enable the HP proxy probe service
  http                  HTTP server configuration
  icmp                  ICMP options
  igmp                  IGMP global configuration
  local                 Specify local options
  name-server           Specify address of name server to use
  options               IP Options treatment
  port-map              Port to application mapping (PAM) configuration commands
  radius                RADIUS configuration commands
  rcmd                  Rcmd commands
  reflexive-list        Reflexive access list
  scp                   Scp commands
  security              Specify system wide security information
  sla                   IP Service Level Agreement
  source                IP source
  source-route          Process packets with source routing header options
  ssh                   Configure ssh options
  sticky-arp            Allow the creation of sticky ARP entries
  subnet-zero           Allow 'subnet zero' subnets
  tacacs                TACACS configuration commands
  tcp                   Global TCP parameters
  telnet                Specify telnet options
  tftp                  tftp configuration commands
  vrf                   Configure an IP VPN Routing/Forwarding instance
WS-C3750X-24P-S
FDR-SW3#show version
FDR-SW3 uptime is 9 hours, 22 minutes
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9-mz.122-55.SE5.bin"
export@cisco.com.
License Level: ipservices
Next reload license Level: ipservices
cisco WS-C3750X-24P (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1648X068
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
Base ethernet MAC Address       : E0:2F:6D:7B:80:80
Motherboard assembly number     : 73-12551-08
Motherboard serial number       : FDO16451FTL
Model number                    : WS-C3750X-24P-S
Daughterboard serial number     : FDO164520EZ
System serial number            : FDO1648X068
Top Assembly Part Number        : 800-31325-07
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COMJR00ARD
*    1 30    WS-C3750X-24P      12.2(55)SE5           C3750E-UNIVERSALK9-M
FDR-SW3(config)#sh    ip ?
  arp                   IP Arp features
  as-path               BGP autonomous system path filter
  bgp-community         format for BGP community
  cef                   Cisco Express Forwarding
  classless             Follow classless routing forwarding rules
  community-list        Add a community list entry
  default-network       Flags networks as candidates for default routes
  dvmrp                 DVMRP global commands
  extcommunity-list     Add a extended community list entry
  forward-protocol      Controls forwarding of physical and directed IP broadcasts
  icmp                  ICMP options
  kerberos              KERBEROS configuration commands
  mrm                   Configure IP Multicast Routing Monitor test parameters
  mroute                Configure static multicast routes
  msdp                  MSDP global commands
  multicast             Global IP Multicast Commands
  multicast-routing     Enable IP multicast forwarding
  ospf                  OSPF
  pim                   PIM global commands
  policy-list           Define IP Policy list
  prefix-list           Build a prefix list
  rcmd                  Rcmd commands
  route                 Establish static routes
  routing               Enable IP routing
  rtcp                  RTCP parameters
  sap                   Global IP Multicast SAP Commands
  scp                   Scp commands
  snap                  Commands affecting SNAP-encapsulated frames
  source                IP source
  verify                URPF config commands
  wccp                  Web-Cache Coordination Protocol Commands
Arunagiri Nallusamy
It is because of the license. In WS-C3750X-48P-L, you have a LANBASE license whereas in WS-C3750X-24P-S you have an IPSERVICES license.
FDR_SW#show  version
In a LANBASE license, ip routing and ip multicast commands are not supported.
Hope  this helps.
Arun
Arunagiri Nallusamy
FDR_SW#show  version
Hope  this helps.
Arun
