ip routing protocol purge interface
munawar.zeeshan
Level 4
Level 4
When i enable IP ROUTING on a 4503 i see this in the running-config
ip routing protocol purge interface.
while if i enable IP ROUTING on a 3507 routing it shows IP ROUTING in the running config.
although ip routing gets enabled by the above mentioned command in 4503, but what exactly the difference is ??
Collin Clark
Might be a default on the IOS you're running. Here is more information on it.
http://cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfindp1.html#wp1053743
HTH and please rate.
