IP SINGLE CLASS /27
fb_webuser
Level 6
Level 6
Router
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
Swicth 0
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 15
interface FastEthernet0/4
switchport access vlan 20
vlan 15
name SALES
vlan 20
name SUPPORT
Switch 2
vlan 15
name SALES
vlan 20
name SUPPORT
PC0
IP: 192.168.15.2
mask:255.255.255.0
GW:192.168.15.1
PC1
IP: 192.168.20.2
mask:255.255.255.0
GW:192.168.20.1
PC2
IP: 192.168.15.3
mask:255.255.255.0
GW:192.168.15.1
PC3
IP: 192.168.20.3
mask:255.255.255.0
GW:192.168.20.1
how can i change this IP address from two networks to a single networking using /27?
Posted by WebUser Charalampos Skeleton C'trattou from Cisco Support Community App
acampbell
Reading your request I think you are aiming to use a /27 for
sales and a different /27 for Support
On your router - reconfigure like this:-
no ip address
ip address 192.168.15.1 255.255.255.224
no ip address
ip address 192.168.15.33 255.255.255.224
end
You will need to readdress your scopes in your
DHCP server if you use one.
Also readdress any static ip addressing your
PCs & printers etc.
Devices in Vlan 15
Ip addresses in the range 192.168.15.2-30
Mask 255.255.255.224
Defauly gateway 192.168.15.1
Devices in Vlan 20
Ip addresses in the range 192.168.15.34-62
Defauly gateway 192.168.15.33
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
no ip address
no ip address
end
PCs & printers etc.
Devices in Vlan 15
Devices in Vlan 20
Alex.
Alex
It is a possible interpretation of the question as being how to change from 2 networks with /24 to 2 networks with /27. But my reading of the original post suggests a different interpretation. I think that the original poster is asking how to combine into a single network which uses a /27.
If I have the correct interpretation then I would observe that the high level solution is fairly simple, though there may be a few complexities as they work through the process. Here is my suggestion of what needs to be done:
- multiple vlans require multiple networks. so if you want a single network then you need a single vlan.
- choose which vlan you will use.
- configure switch access ports in this vlan.
- remove the vlan that you will not be using.
- since there is a single vlan there is no need for switch ports. chane all ports currently configured as trunk to be access ports in the new vlan.
- with a single vlan/single network there is no need for vlan subinterfaces on the router. so remove the subinterfaces on the router.
- configure the router interface with an IP address and subnet mask for the new subnet.
- if there is DHCP to provide addressing information to clients then change the DHCP server to have a new scope for the new subnet. (and you can remove the old scopes)
Rick
Rick
