Port Channel in Nexus
Sagar Purohit
Hi All,
I have a scenario where I have two nexus 5596 as upstream and have vPC  in between. downstream is the server hooking to the upstrean both nexus  devices.
On Both the Nexus switch the port channel is down and the VPC is also  down. The physical interfaces are up and passing traffic to the server.
My understanding is if the server NIC's are teamed, even the switches should also have the portchannle to work properly.
But since portchannel and vpc both are down in both the switches
1. how the switch is passing traffic.
2. I checked the configs for portchannel formation on phy ports which looks good to me still po is down. Why?
3. I understand as port channel is down so vPC is down ( correct me if I am wrong).
I have attached the diagram & below are the logs for ur reference:
The output on Nexus5596 2 device is same as on Nexus5596 1
Nexus5596 1#Sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 106
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : primary
Number of vPCs configured       : 29
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po4    up     1-2,713-718,999
vPC status
id     Port        Status Consistency Reason                     Active vlans
9      Po9         up     success     success                    2,713-718
701    Po701       down*  success     success                    -
702    Po702       down*  success     success                    -
Nexus5596 1# sh port-channel su
Group Port-       Type     Protocol  Member Ports
      Channel
4     Po4(SU)     Eth      LACP      Eth1/27(P)   Eth1/28(P)
9     Po9(SU)     Eth      LACP      Eth1/29(P)   Eth1/30(P)   Eth1/31(P)
                                                    Eth1/32(P)
701   Po701(SD)   Eth      LACP      Eth1/1(I)
702   Po702(SD)   Eth      LACP      Eth1/2(I)
Nexus5596 1#sh run int e1/1
interface Ethernet1/1
  description snrkdc1285_1/0
  switchport mode trunk
  switchport trunk native vlan 713
  switchport trunk allowed vlan 713-718
  spanning-tree port type edge trunk
  no snmp trap link-status
  channel-group 701 mode active
Nexus5596 1# sh int e1/1 status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/1        snrkdc1285_1/0     connected trunk     full    10G     10Gbase-SR
Sagar
Reza Sharifi
According to your diagram, Portchannel 701 should have port e1/0 in it in each of the 5500 switches, but below output shows port e1/1
Can you post the portchannle configs or sh run from both switches?
glen.grant
  Is the port channel SVI admin up  ?  Can you post a show running int port-channel 702  ?  Does a sow ip int brief show the SVI as admin up ?
Reza - My bad I mistakenly mentioned e1/10 in diagram but it is e1/1 for po701
Since these are L2 switches SH IP INT BR shows only mgmt Ip
Please find the requested outputs as below.
nexus5596 1#sh run int po701
interface port-channel701
  speed 10000
  vpc 701
nexus5596 2# sh run int po701
  speed 10000
  vpc 701
nexus5596 1#sh int br
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        713     eth  trunk  up      none                        10G(D) --
Eth1/2        713     eth  trunk  up      none                        10G(D) --
Port-channel VLAN    Type Mode   Status  Reason                    Speed   Protocol
Interface
Po4          1       eth  trunk  up      none                       a-10G(D)  lacp
Po9          2       eth  trunk  up      none                       a-10G(D)  lacp
Po701        713     eth  trunk  down    No operational members       10G(D)  lacp
Po702        713     eth  trunk  down    No operational members       10G(D)  lacp
nexus5596 2#sh int br
Interface        Ch #
Interface
kunkelta
Are you sure the server is configured for a LACP port channel and not just for nic teaming? I think the (i) status indicates you are not getting LACP from the server.
Tom
