11-13-2013 11:04 AM - edited 03-07-2019 04:35 PM
copied config from 2960S
cannot set "ip sla enable reaction-alerts" on new switch:
WS-C2960X-24PS-L 15.0(2)EX3 C2960X-UNIVERSALK9-M
get:
comp-room-2#ip sla enable reaction-alerts
% Invalid input detected at '^' marker."
what am i doing wrong
thanks
11-13-2013 11:45 AM
Hi Jacob,
First go to config mode and the run this command:
comp-room-2# Config t
comp-room-2(Config)# ip sla enable reaction-alerts
Try this.
Please rate helpful posts.
11-13-2013 11:57 AM
sorry
i pasted the wrong text
this is what i get
comp-room-2(config)#ip sla enable reaction-alerts
the marker on the word enable
when i do ip sla ?
i get
comp-room-2(config)#ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
11-13-2013 12:11 PM
Hi Jacob,
To use Cisco IOS IP Service Level Agreements (SLAs), the switch must be running the LAN Base image.
I think ur image did not support this feature.
Paste the sh version output or to check if your Image supports IP SLA or not: Please check here: http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
11-14-2013 03:41 AM
comp-room-2#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 11-Sep-13 02:04 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.0(2r)EX, RELEASE SOFTWARE (fc1)
comp-room-2 uptime is 1 day, 1 hour, 6 minutes
System restarted at 13:32:26 UTC Wed Nov 13 2013
System image file is "flash:/c2960x-universalk9-mz.150-2.EX3/c2960x-universalk9-mz.150-2.EX3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FOC1741S091
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 64:E9:50:C9:38:00
Motherboard assembly number : 73-14193-03
Power supply part number : 341-0528-01
Motherboard serial number : FOC17403J4S
Power supply serial number : DCB173273ZU
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C2960X-24PS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC173917SL
System serial number : FOC1741S091
Top Assembly Part Number : 800-38007-01
Top Assembly Revision Number : A0
Version ID : V01
CLEI Code Number : CMMLR00ARA
Daughterboard revision number : A0
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24PS-L 15.0(2)EX3 C2960X-UNIVERSALK9-M
11-16-2013 11:22 PM
anyone?
11-17-2013 12:47 AM
Hi Jacob,
I did nt find any exact reaction.
Please try to update the IOS.
This IOS hav many bugs.
https://supportforums.cisco.com/thread/2236950
Hope it helps.
02-06-2018 05:37 PM
SW-01#sh ver | i 15.2
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E, RELEASE SOFTWARE (fc3)
* 1 28 WS-C2960X-24PS-L 15.2(2)E C2960X-UNIVERSALK9-M
SW-01(config)#ip sla enable
SW-01(config)#ip sla ?
What else can I try to be able to do 'ip sla enable reaction-alerts' on 2960X?
Ricky
01-21-2021 12:16 AM
I know it's so late but I'm just letting you know.
You may hitting bug CSCtb35715 .
