IP SLA for https ??
wpalumbo06
Level 3
Level 3
I need to configure an http get IP SLA but need to retrieve a webpage from a device that only supports https (Cisco ISE).  Everything that I have read so far only references http.  Is it possible to configure this?  If so, can you include a link to where that is referenced?
Thank you,
6 Replies 6
Mark Malone
I don't think its officially supported , I have never tested this but the syntax is available you could try something like the below see if it works for you the 443 being the https bit
ip sla 99
 http get http://134.18.1.9 source-ip 10.1.1.1 source-port 443
 frequency 10
Thanks Mark but I don't think specifying the source port will work for what I need.  ISE appears to do a redirect to https if you send it an http get, so the IP SLA **appears** to be working - we'll see.
One thing that's odd is that the success/failure counters seem to reset periodically - I don't see any config options for that..weird.
did you ever get IP SLA working for HTTPS?
Cheers,
Johan
No.  I configured the IP SLA anyway on a hunch that it might work since ISE will respond to http and then immediately redirect to https.  Seems to be working so far.
ok. thanks for the quick reply.
I don't think https works.
there is no commands to specify the target port.
