ip sla function question !
systemant
Community Member
Hello guys
My lab config~
ip sla 1
icmp-echo 1.1.1.2 source-interface Serial0/0
timeout 10000
frequency 10
ip sla schedule 1 life forever start-time now
track 1 rtr 1 reachability
ip route 192.168.1.0 255.255.255.0 1.1.1.2 track 1
ip route 192.168.1.0 255.255.255.0 2.2.2.2 10
When ping 1.1.1.2 onces is fail every 10s , ip sla switch routing .
How does cofonigure ip sla when ping 1.1.1.2 three times is fail ( 3 * 10s = 30s ), ip sla switch routing .
Have any command can do that ?
ios ~
12.2(55)SE3           C3750-IPSERVICESK9-M
AhmedSonba
Level 5
Level 5
Hello
Let me see If got you right , you want to delay te process of changing from the main to the  backup route and in your case its from 1.1.1.1 to 2.2.2.2
You can do that by  increasing  the delay  from the command track 1 where you can adjust down and the up time up to 180 Seconds
Example:
Router(config)# track 1 rtr 1 reachability
Router(config-track)# delay down 30
Router(config-track)# delay up 30
In this case it will be delaied 30 Seconds
Please refer to the below link for more information
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/fthsrptk.html#wp1027188
Hope it helps and let me know in case you need any further help
Ahmed Sonba
AhmedSonba
Level 5
Level 5
Hello
Example:
Ahmed Sonba
