IP sla is not working
onlinerecharge
Hi i am facing a huge problem in IPSLA in cisco 3650 switch,
problem is my track is now being down at the time of link failure. thats why static route is not inappear from routing table.
here is the configuration file,
track 422 ip route 221.135.132.98 255.255.255.255 reachability
ip route 221.135.132.98 255.255.255.255 192.168.200.200 track 422                               ----- tracking route
ip route 0.0.0.0 0.0.0.0 192.168.200.200 track 422                                                          ------ primary router
ip route 0.0.0.0 0.0.0.0 192.168.200.100 200        -------secondary router
ip route 10.10.10.0 255.255.255.0 192.168.200.100
ip route 30.30.30.0 255.255.255.0 192.168.200.100
ip sla 422
icmp-echo 221.135.132.98
threshold 1000
timeout 1000
frequency 5
please tell me what is the misconfiguration here
cadet alain
ip sla schedule 422 life forever start now
no ip route 221.135.132.98 255.255.255.255 192.168.200.200 track 422
no track 422 ip route 221.135.132.98 255.255.255.255 reachability
track 422 rtr 422 reachability
Alain
Bilal Nawaz
Hello, could you kindly tell us the topology, where is your 3560 connected to, how does the primary router and secondary router come in to the frame. Which IPs belong where? A running config would be good to see?
Also I noticed you have a default route with the track command and the other static route too. Both of these will be taken out of the routing table since 422 is unreachable/down.
IP SLA is working if the tracked routes gets taken out when 221.135.132.98 is unreachable... Im not sure it this is the case.
Then the Ip route 0.0.0.0 0.0.0.0 192.168.200.100 200 should come active.
You can see my working example I tested in a lab couple of days ago:
https://supportforums.cisco.com/message/3900451#3900451
I would do this, however sla and track commands vary from IOS:
ip sla monitor 422
type echo protocol ipIcmpEcho 221.135.132.98
frequency 5
ip sla monitor schedule 422 life forever start-time now
ip route 0.0.0.0 0.0.0.0 192.168.200.200 track 422 [Primary]
ip route 0.0.0.0 0.0.0.0 192.168.200.100 200 [Secondary]
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
cadet alain
Alain
Thank you so much problem got resolved
Only one problem i am having this track got down frequently and came up within 5 seconds. I am not able to understand why it goes down so frequently?
