IP SLA not recovering after failover (depending on...)
Michael Durham
Level 4
Level 4
Here iis a diagram of my current lab where I am using IP SLA to automatically switch from ISP 1 to ISP 2 should the connection go down (and vice versa)
My switches are C3550 Layer 3 switches.  Both ISP's do work so connectivity is not the problem.
If I shutdown the fa0/19 port on SW1 the SLA kicks in and changes my defualt route out 10.0.1.0 without a problem.  And when I do a no shut it comes back to tge 192.168.10.0 netowrk just as we would expect.  No problem there.
When I disconnect the ISP 1 cell phone the SLA does switch the defualt route to the 10.0.1.0 netowrk.  Okay, just fine so far.  Here isthe problem, when i reconnect the cell phone the SLA does not come back to the 192.168.10.0 netowrk without first having to delete the SLA and then recresting it (both switches).
Any suggestions?  My complete config files for both switches are attached.
8 Replies 8
Abzal
Level 7
Level 7
I looked at your configs. Try to remove one track objects (which is considered as backup) on ip routes on both switches. Something like this:
SW1:
no ip route 0.0.0.0 0.0.0.0 10.0.1.1 track 20
ip route 0.0.0.0 0.0.0.0 10.0.1.1 250
SW2:
no ip route 0.0.0.0 0.0.0.0 192.168.10.2 track 10
ip route 0.0.0.0 0.0.0.0 192.168.10.2 250
In this way in case of failure of primary route second route through neighbor switch will take over. Because backup route has AD 250 it will be put in RIB only in case of failure of primary. Once primary comes online backup route will be deleted from routing table due to higher AD.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Thank you for the suggestion but it is not the answer I am seeking.
The problem is if the clee phone is just unplugged  get the followiing error:
Server_Switch#sh ip sla stat
Round Trip Time (RTT) for       Index 1
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: .00:40:16.418 Eastern Fri Jan 11 2013
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 891
Operation time to live: Forever
Round Trip Time (RTT) for       Index 2
        Latest RTT: 4 ms
Latest operation start time: .00:40:17.294 Eastern Fri Jan 11 2013
Latest operation return code: OK
Number of successes: 368
Number of failures: 0
And when I reconnect the cell phone, the error should automaticall go back to OK in Index 1 but it does not on both switches.
If one of the switches would come back online then your suggestion might help get the second one up too.
Still seeking a suggestion.
Hi Michael,
Is above output from SW1 or SW2?
When ISP 1 cell phone comes back online are you able to ping it and 192.168.42.129 from SW1?
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
That output was from SW2.  However, it is the same from SW1 even after the cell phone is reconnected.
Yes, I can ping 192.168.42.129 from both switches even thought the SLA still shows it in timeout.
Please remember, if I enther the following commands before I disconnect the cell phone,
SW1(config)# int fa0/19
SW1(config-if)# shut
and later connect the cell phone back to the ICS box and issue these commands:
SW1(config-if)# no shut
SLA recovers correctly and I get the following output on both switches:
        Latest RTT: 1 ms
Latest operation start time: .10:10:03.518 Eastern Fri Jan 11 2013
Number of successes: 4
Number of failures: 2673
        Latest RTT: 3 ms
Latest operation start time: .10:10:04.394 Eastern Fri Jan 11 2013
Number of successes: 2154
If only there were DSL or cable services in my area, I would not have to be dealing with this issue.
(Server_Switch is SW2 and Office_Switch is SW1)
I'm not sure but when you'll be ready to test it again try to remove port-security on port F0/19 on SW1. Or when cell phone goes offline and then again comes back online see a status of the port.
SW1 (status of the port):
show int status
int f0/19
no switch port-secur
no switchport port-security violation protect
no switchport port-security mac-address sticky
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
I tried your suggerstions but they did not help.  Below are my results:
Switch working correctly:
Office_Switch#sh int stat | b /19
FastEthernet0/19
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor          0          0       7949     555690
             Route cache          0          0          0          0
                   Total          0          0       7949     555690
Office_Switch#sh ip sla stat
        Latest RTT: 1 ms
Latest operation start time: .10:52:56.917 Eastern Fri Jan 11 2013
Number of successes: 836
        Latest RTT: 8 ms
Latest operation start time: .10:52:56.945 Eastern Fri Jan 11 2013
Number of successes: 2638
Number of failures: 1
AFTER cell phone is disconnected (NOT by shutting down the port):
FastEthernet0/19
               Processor          0          0       8043     562030
             Route cache          0          0          0          0
                   Total          0          0       8043     562030
Latest operation start time: .10:54:26.919 Eastern Fri Jan 11 2013
Number of successes: 880
Number of failures: 46
        Latest RTT: 12 ms
Latest operation start time: .10:54:26.947 Eastern Fri Jan 11 2013
Number of successes: 2728
After cell phone re-connected:
FastEthernet0/19
               Processor          0          0       8172     571170
             Route cache          0          0          0          0
                   Total          0          0       8172     571170
Latest operation start time: .10:57:38.923 Eastern Fri Jan 11 2013
Number of failures: 238
        Latest RTT: 4 ms
Latest operation start time: .10:57:39.951 Eastern Fri Jan 11 2013
Number of successes: 2921
Office_Switch#ping 192.168.42.129
Sending 5, 100-byte ICMP Echos to 192.168.42.129, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Office_Switch#
An hour later still no change.  But as soon as I do the following, it works!
Office_Switch(config)#no ip sla 1
Office_Switch(config)#ip sla 1
Office_Switch(config-ip-sla)# icmp-echo 192.168.42.129 source-ip 192.168.10.1
Office_Switch(config-ip-sla-echo)# timeout 500
Office_Switch(config-ip-sla-echo)# frequency 1
Office_Switch(config-ip-sla-echo)#exit
Office_Switch(config)#ip sla schedule 1 life forever start-time now
Office_Switch(config)#end
        Latest RTT: 1 ms
Latest operation start time: .11:59:02.607 Eastern Fri Jan 11 2013
        Latest RTT: 7 ms
Latest operation start time: .11:59:03.031 Eastern Fri Jan 11 2013
Number of successes: 3000
Number of failures: 5
Looks like a bug for me. I've never expirienced such a problem. You may try to upgrade it.
What is the version of IOS you running?
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
System image file is "flash:c3550-ipservices-mz.122-44.SE6/c3550-ipservices-mz.122-44.SE6.bin"
The latest version from what I have seen.
