06-03-2012 10:16 AM - edited 03-07-2019 07:02 AM
Hi.
Can anyone tell me, why i cant correctly use ip sla command. I only have on my 2901 such commands:
ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
server IPPM server configuration
There is my "sh ver"
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
And...What should i do. if i want to create a failover with to WANs
06-03-2012 11:25 AM
You need the DATA license key to support IP SLA.
HTH,
John
06-03-2012 08:18 PM
Ok.Thx
09-24-2020 12:05 AM
John,
Where can you verify which features need licenses?
Thanks.
