Showing results forĀ
Search instead forĀ
Did you mean:Ā
ip source guard and no dhcp binding
sarahr202
Level 5
Level 5
Hi everybody.
Ip source guard uses dhcp binding table or static binding to dynamically create acl.
h1-------f1/1sw-------dhcp server
sw is configured with ip source guard  on its port f1/1
h1 just powers up and needs an ip address so it sends an  broadcast looking for dhcp server. The switch receives the broadcast frame from h1.How will switch react?( keep in mind,  there is no dhcp binding as it is the very first frame from h1. Also src ip in received frame from h1, is blank i.e 0.0.0.0)
thanks and have a great weekend.
Reza Sharifi
Hi Sarah,
From the config guide:
Initially, all IP traffic on the protected port is blocked except for DHCP packets. After a client receives
an IP address from the DHCP server, or after static IP source binding is configured by the administrator,
all traffic with that IP source address is permitted from that client. Traffic from other hosts is denied.
This filtering limits a host’s ability to attack the network by claiming a neighbor host’s IP address.
IP Source Guard is a port-based feature that automatically creates an implicit port access control list
Here is the link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/ipsrcgrd.pdf
Have a nice weekend
Reza Sharifi
Hi Sarah,
Here is the link:
Have a nice weekend
