IP Subnetting
hassaan_st
Community Member
I am facing some problem with the IP subnetting...
We have 3 classes being used for subnetting.
Class A: 1 to 126
1.0.0.0 - 126.255.255.255
Class B: 128 - 191
128.0.0.0 - 191.255.255.255
can we use network 191.255.0.0
Class C: 192 - 223
192.0.0.0 - 223.255.255.255
can we use network 223.255.255.0 ?
Another confusion is with regard to the number of networks available in a specific class.
Lets talk about Class A.
We have last three octets reserved for Hosts and Subnets, which means we can have 16777214 hosts ... however what about the Number of Networks in Class A?
In few of the sites they have calculated
2^7-2 = 126 networks for class A.
Whereas in Cisco site they dont subtract 2 for determining Number of Networks ...
Plus why 2^7 for networks, why not 2^8?
Waiting for some quick responses
Thanks and regards
mheusing
Yes, the networks 191.255.0.0/16 and 223.255.255.0/24 can be used.
As to how many networks are available in a class A network:
It really depends on the masks you are using for subnetting. Today we are using Variable Length Subnet Mask (VLSM), which basically means that the length of the subnet mask does not have to be fixed to the same value everywhere in a network.
Lets take 10.0.0.0/8 as an example.
You can configure 16777216 host routes starting from 10.0.0.0/32, 10.0.0.2/32, ..., 10.255.255.254/32 to 10.255.255.255/32
OR 4194304 routes with /30 OR ... OR 2 routes with /9 namely 10.0.0.0/9 and 10.128.0.0/9
With VLSM you can also have combinations like 10.128.0.0/9 and 10.0.0.0/24 and 10.0.123.32/28 and 10.23.45.67/32 all in the same network.
As you might see now the answer to the question "What is the number of networks in a Class A?" can be between 2 and 16777216 and depends on the subnetmask(s) used.
The main task when subnetting is to avoid duplicate and overlapping IPs. You should not use e.g. 10.1.0.0/16 and 10.1.1.0/24 in two different places or have two hosts with e.g. 10.98.98.98 as then connectivity can be affected or prevented.
Hope this helps!
Martin
vishwancc
Level 6
Level 6
2^7 is because it start from 2^0 to 2^7 (0 to 7 is 8 bit) and (0 to 8 will be 9 bit) if we use 2^8
Class B: 128 - 191
can we use network 191.255.0.0 YES
Class C: 192 - 223
can we use network 223.255.255.0 YES
Check this link
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800a67f5.shtml
Chao
Vishwa
Thanks for the help
2^7 concept is logical for sure
however when we talk abt determining the total number of hosts per network, then we use 8 instead of 7
e.g. Total Number of Hosts in Class C (using the default subnet mask of 255.255.255.0) is 2^8-2.
As per the above mentioned logic, should'nt we use 2^7-2 here?
thanks
