ip summary-address eigrp X 0.0.0.0 0.0.0.0 in eigrp named mode
gongya001
When I configured ip summary-address eigrp 10 0.0.0.0 0.0.0.0 in classic mode, it works, but it does not work in named mode.
How to advertise a default route into an eigrp network ?
thanks !!
brselzer
The configuration for interfaces moves into the router eigrp section of the config under the af-interface section:
Old Config
int gig0/1
ip eigrp 100 summary address 0.0.0.0 0.0.0.0
router eigrp 100
New config
router eigrp NAME
address-family ipv4 unicast autonomous system 100
af-interface gig0/1
If you move the configuration here, it should continue to work as it has before.
Hope that helps!
-Bradley Selzer
CCIE# 60833
thanks !!
gongya001
figured it out. it should be under af-interface.
thanks !!
