IP supernetting calculator
Hi All,
Can anybody help me to know the link for online supernetting calculator?
Thiyagu
11 Replies 11
milan.kulik
Level 10
Level 10
I have tried using the below but I'm not getting the tab to enter the list of IP address to summarize. Can you help me on this?
http://www.subnet-calculator.com/cidr.php
AhmedSonba
Please find below a link for a subnetting calculator for Android it will be really useful if you would use it when you are on the move.
http://www.androidzoom.com/android_applications/tools/ip-subnetsupernet-calculator_gagf_download.html
Hope it will Help
Ahmed Sonba
AmosLucian5018
Im using this free online tool to solve supernetting problems:
https://calculadoraip.org/supercalc/
Changed domain to this I think: https://calculadoraip.org/supercalc/
artzowi8
i think best supernetting calculator keep on your bookmark is this
https://www.one-calculator.com/online-ip-subnet-calculator.html
features:
-calculate Hosts number per Subnet,Wildcard Mask ,Subnet Mask
-give you (first address - last address - brodcast address - id network) per Subnet
-give you also Subnet Bits,Maximum Subnets
-give table have all Network Details using binary system
-give table have all Possible Network (Network Address,Usable Host Range,Broadcast Address)
Im using this one:
And it goes very well
Yes, all calculators do the job, but I prefer this calculator https://www.one-calculator.com/online-ip-subnet-calculator.html , which is easy to use and contains everything I want
and https://www.one-calculator.com have handy calculator for networking
-CIDR Calculator
-Wildcard Mask Calculator
-IP Range Address Calculator
-Broadcast Address Calculator
Joseph W. Doherty
As @AmosLucian5018 has "refreshed" this decade plus old posting, I suspect it's somewhat unlikely to find any subnet calculator that supports actual supernetting, but supernets might be obtained using any subnet calculator that supports classless IPv4.
BTW within classful IPv4, supernets vs. subnets depend on what class of IPv4 address space you're working with.  For example, 172.16.0.0/20 is a subnet but 192.168.0.0/20 is a supernet.  Using classless IPv4, both of the forgoing are /20 networks.
sebt11tools
Finding an online supernetting calculator is relatively easy. There are several websites and tools available that can assist you in calculating supernetting.
AmosLucian5018
https://calculadoraip.org has all available calculators of subnetting:
IP calculator (include subnets): https://calculadoraip.org/ipcalc/
Supernetting: https://calculadoraip.org/supercalc/
FLSM: https://calculadoraip.org/flsmcalc/
VLSM: https://calculadoraip.org/vlsmcalc/
IPv6 calculator: https://calculadoraip.org/v6/
Optimistic big networks calculator: https://calculadoraip.org/optimista/
Pesimistic big networks calculator: https://calculadoraip.org/pesimista/
All the calculators include a PDF button where you can download your problems.
Also, the web includes cheatsheets for everything related to networks and free CyberOps and CCNA1 courses.
Just try it you won't regret!
I leave an example of what you can do.
