L3 Switches connecting to Firewalls
RMS3
Hi All,
I have a topology as shown below:
The Firewalls A & B are running as active/standby. I have an etherchannel configured between L3 Switch A and Switch B. The switches also have HSRP running for various VLANs.
The link between Switch and Firewalls are routed ports. I have the following issues:
1) The routed port of Sw A isnt pinging routed port of Sw B
2)The switches dont detect topology change (Active/Standby change) in the Firewall level. The switch connected to the active firewall alone works while the switch connected to standby firewall isnt able to reach the FW IP.
Ideally I should have had redundant links between the switches and firewalls,unfortunately this was overlooked.
Could someone please explain what is happening in both the cases mentioned above?
Thanks.
Hello @RMS3
When two Layer 3 switches with routed ports are not able to ping each other, this might be du.e to a few reasons:
Routed Ports Not Pinging Between Switch A and Switch B:
May be Configuration Mismatch, EtherChannel Misconfiguration, Routing Table Issues, Physical Link Problems.
Switches Don't Detect Topology Changes in Firewalls:
Missing Redundancy, HSRP Failover Configuration, Firewall Failover Communication, Routing Issues.
To address these issues, consider the following recommendations:
  • Add Redundancy: Redundant links between switches and firewalls can ensure continuous connectivity when the active/standby status changes.
  • Reconfigure EtherChannel and HSRP: Double-check the configuration to ensure correct setup. Confirm there are no misconfigurations in the channel groups, protocols, HSRP group numbers, or priorities.
  • Monitor and Test: Implement monitoring to detect topology changes and test failover scenarios to ensure proper behavior. Use tools like SNMP and syslog to monitor for failures and alert when topology changes occur.
  • Consult Firewall Documentation: Check the firewall's documentation for specific details about the high-availability setup and ensure it is correctly configured.
if you get idea then click the helpful for more support like this.
