ip to interface
aaroncward
Is there a way/command to look up a the router name and interface number by an ip address.
Richard Burts
aaron
Depending on how you have set up your DNS it is quite possible to do a DNS lookup on the IP address and to get the router name and interface identifier. You just need to be sure that you build DNS records for each interface address that include the router name and identification of interface as part of the defined name.
Rick
Rick
aaroncward
the is internaly and the last route is the VTP server
