ip unnumbered with 2 FE Ints?
wazza_bayer
Community Member
Is it possible to use ip unnumbered on fasteth interfaces?
With the following config, if we connect a device with 192.168.122.2/24 to FE 0/0 we are unable to ping 192.168.122.1?
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
ip unnumbered FastEthernet0/1
interface FastEthernet0/1
ip address 192.168.122.1 255.255.255.0
duplex auto
speed auto
Richard Burts
What kind of device is it and how is it connected to FA0/0?
The use of ip unnumbered was originally restricted to point to point serial interfaces. Cisco has extended the concept and now you can configure VLAN subinterfaces of a router as ip unnumbered. This presumes that the connection on the interface is a trunk. So is the device that is connected doing trunking?
Rick
Rick
The device currently connected to FA0/0 is simply a Laptop - We will be connecting the router(1841) to a cisco switch and running dot1q.
So, if we have somthing like:
interface FastEthernet0/0.10
encapsulation dot1Q 10
With vlan 10 running on switch port, and a trunk port back to 1841 FA0/0, it should work?
I believe that this should work.
Rick
Rick
