IPC-SW1_STBY-5-WATERMARK and RPC-SW2-4-CORE_SAT_RPC_FAIL logs
kinshaun0512
I got the logging error message about IPC and RPC below. I have checked CPU and memory is working fine.
Nov 23 19:17:45 AEST: %IPC-SW1_STBY-5-WATERMARK: 2882 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3090000
Nov 23 19:18:24 AEST: %IPC-SW1_STBY-5-WATERMARK: 6191 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3030000
Nov 23 19:21:27 AEST: %RPC-SW2-4-CORE_SAT_RPC_FAIL: RPC between Core and Remote Switchvs_rp_environmental:env_clear_alarm_rp failed (non-fatal). Expected when VSL goes down.
Nov 23 19:23:54 AEST: %RPC-SW2-4-CORE_SAT_RPC_FAIL: RPC between Core and Remote Switchvs_rp_environmental:env_raise_alarm_rp failed (non-fatal). Expected when VSL goes down.
Possibly is this related to bug id CSCso14087? I couldn't find a bug related to the RPC fail though. Here is a cropped show version output.
SWITCH1#sh ver
Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9-M), Version 15.1(2)SY6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 10-Sep-15 01:36 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
If you require further outputs to troubleshoot, do let me know.
Thanks in advance, will provide rating for help on answering.
5 Replies 5
Paul Chapman
Level 4
Level 4
Hi -
Post results of the following commands.
show redundancy states
show platform hardware pfc mode
show switch virtual
show switch virtual role
show switch virtual link
PSC
Paul, here are the requested output from the device where we picked up logs showing these error.
Nov 24 03:38:41 AEST: %RPC-SW2-4-CORE_SAT_RPC_FAIL: RPC between Core and Remote Switchvs_rp_environmental:env_raise_alarm_rp failed (non-fatal). Expected when VSL goes down.
Nov 24 03:29:59 AEST: %IPC-SW1_STBY-5-WATERMARK: 6374 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3080000
Nov 24 03:30:40 AEST: %IPC-SW1_STBY-5-WATERMARK: 2968 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3090000
Nov 24 03:31:12 AEST: %IPC-SW1_STBY-5-WATERMARK: 6377 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3010000
Nov 24 03:32:26 AEST: %IPC-SW1_STBY-5-WATERMARK: 6375 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3080000
Nov 24 03:32:59 AEST: %IPC-SW1_STBY-5-WATERMARK: 6375 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3030000
Nov 24 03:33:39 AEST: %IPC-SW1_STBY-5-WATERMARK: 6077 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3050000
Nov 24 03:34:53 AEST: %IPC-SW1_STBY-5-WATERMARK: 6376 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3080000
Nov 24 03:35:26 AEST: %IPC-SW1_STBY-5-WATERMARK: 6376 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3030000
Nov 24 03:36:00 AEST: %IPC-SW1_STBY-5-WATERMARK: 2969 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3090000
Nov 24 03:37:21 AEST: %IPC-SW1_STBY-5-WATERMARK: 6377 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3080000
Nov 24 03:37:54 AEST: %IPC-SW1_STBY-5-WATERMARK: 6377 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3030000
Nov 24 03:38:33 AEST: %IPC-SW1_STBY-5-WATERMARK: 6079 messages pending in rcv for the port Card22/0:Request(3060000.C) seat 3050000
Nov 24 03:42:21 AEST: %RPC-SW2-4-CORE_SAT_RPC_FAIL: RPC between Core and Remote Switchvs_rp_environmental:env_clear_alarm_rp failed (non-fatal). Expected when VSL goes down.
HS-EN-XD-1#show redundancy states
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Duplex
Unit = Secondary
Unit ID = 38
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured) = sso
Redundancy State = sso
Maintenance Mode = Disabled
Manual Swact = disabled (the peer unit is still initializing)
Communications = Up
client count = 143
client_notification_TMR = 30000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 18
RF debug mask = 0x0
HS-EN-XD-1#show platform hardware pfc mode
PFC operating mode : PFC4
Configured PFC operating mode : non-XL
HS-EN-XD-1#show switch virtual
Switch mode : Virtual Switch
Virtual switch domain number : 20
Local switch number : 2
Local switch operational role: Virtual Switch Active
Peer switch number : 1
Peer switch operational role : Virtual Switch Standby
HS-EN-XD-1#show switch virtual role
RRP information for Instance 2
Valid Flags Peer Preferred Reserved
Count Peer Peer
TRUE V 1 1 1
Switch Switch Status Priority Role Local Remote
Number Oper(Conf) SID SID
LOCAL 2 UP 100(100) ACTIVE 0 0
REMOTE 1 UP 200(200) STANDBY 8918 7005
Peer 0 represents the local switch
Flags : V - Valid
In dual-active recovery mode: No
HS-EN-XD-1#show switch virtual link
VSL Status : UP
VSL Uptime : 2 years, 7 weeks, 3 days, 18 hours, 52 minutes
VSL SCP Ping : Pass
VSL ICC Ping : Pass
VSL Control Link : Te2/5/4
VSL Encryption : Configured Mode - On, Operational Mode - On
Looks like you have failed over to the supervisor on chassis 2 and the sup on chassis 1 is having a problem. You should connect a console cable to the sup on chassis 1 and see what is happening.  Is it constantly rebooting?
PSC
i dont think so..see redundancy status below.
strangely i saw switch environment alert much earlier but then it resolved by itself.
still checking.. any useful suggestions or inputs are very much welcomed.
witch environment alert resolved.
HS-EN-XD-1#sh environment alarm switch 2
environmental alarms:
no alarms
HS-EN-XD-1#sh environment alarm switch 1
no alarms
HS-EN-XD-1#sh clo
09:25:54.401 AEST Thu Nov 24 2016
system minor alarm on switch 2 power-supply 1 power-output-fail (raised 00:01:59 ago)
HS-EN-XD-1#sh clo
01:29:13.785 AEST Thu Nov 24 2016
HS-EN-XD-1#show redundancy switchover
Switchovers this system has experienced : 5
Last switchover reason : active unit failed
Uptime since this supervisor switched to active : 29 weeks, 1 day, 14 hours, 16 minutes
Total system uptime from reload : 2 years, 7 weeks, 4 days, 50 minutes
HS-EN-XD-1#sh clo
09:30:41.447 AEST Thu Nov 24 2016
Hi -
Based on your output, I'm not really changing my opinion about your standby chassis.
  1. Switchover occurred 29 weeks ago
  2. Switchover reason: "active unit failed"
  3. Chassis 2 is active, not standby (atypical)
If you do a "show module switch all" what is the status of the supervisor in chassis 1?
Can you connect to the standby supervisor using "remote login standby"?
PSC
