IPSec tunnel up no traffic
avwoudenberg
I have an IPSec tunnel configured on my Cisco 1941. The other device is an ZyXEL router.
I can see the tunnel is up but there is no traffic.
This comes out the show crypto ipsec sa
interface: Dialer1
    Crypto map tag: CMAP_AVW, local addr 10.10.10.89
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.200.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.150.0/255.255.255.0/0/0)
   current_peer 20.20.20.161 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 708, #pkts encrypt: 708, #pkts digest: 708
    #pkts decaps: 1167, #pkts decrypt: 1167, #pkts verify: 1167
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 9, #recv errors 0
     local crypto endpt.: 10.10.10.89, remote crypto endpt.: 20.20.20.161
     path mtu 1492, ip mtu 1492, ip mtu idb Dialer1
     current outbound spi: 0xB40221B0(3020038576)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x8F853118(2407870744)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Tunnel, }
        conn id: 2017, flow_id: Onboard VPN:17, sibling_flags 80000046, crypto m
ap: CMAP_AVW
        sa timing: remaining key lifetime (k/sec): (4497592/2744)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2018, flow_id: Onboard VPN:18, sibling_flags 80000046, crypto m
ap: CMAP_AVW
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
interface: Virtual-Access2
     inbound esp sas:
ap: CMAP_AVW
        IV size: 8 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
ap: CMAP_AVW
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
I also add the config.
Can someone help me with this?
Thanks a lot.
Tagir Temirgaliyev
this is traffic
make several times
if bold digits grows so ipsec works
dont forget to rate post
access-list 23 permit 192.168.200.0 0.0.0.255
access-list 23 permit 192.168.150.0 0.0.0.255
Please remove these statements and then check.
Also Check on both Side
Client A must have Gateway of A Router Inside LAN
Cleint B musth have Gateway of B Router Inside LAN.
*** Do Rate Helpful Posts***
Hi ttemirgaliyev,
Yes, your right. This is traffic. I found out what is the problem.
I can ping all network devices in the 192.168.200.0 subnet, except the 2 servers 192.168.200.2 and 192.168.200.242
These 2 servers connect to the internet through 2 other ip addresses from the subnet than the one which is on the dailer1.
ip nat inside source static 192.168.200.2 10.10.10.90
ip nat inside source static 192.168.200.242 10.10.10.91
IP address on dialer1 is 10.10.10.89
10.10.10.89 is also the ip address which is used by the 192.168.200.0 subnet.
So, I think that I know where the problem is came from, but don't know how to fix it.
I hope you can help me with it.
Thanx a lot again.
Kind regards,
Albert
