09-11-2017 07:55 AM - edited 03-08-2019 11:59 AM
Hi Team,
I have a Cisco 2811 device running with "c2800nm-advsecurityk9-mz.124-22.T2.bin" we have configured failover mechanism in to the same chassi.
ip sla 1
icmp-echo <isp ip> source-ip <ip address>
threshold 2500
frequency 120
timeout 3000
ip sla schedule 1 life forever start-time now
once the device is rebooting the same configuration is erracing automatically more over even if we configure source ip after saving the same is changing surce IP as 0.0.0.0
Kindly comment on the exact issue on the device.
Solved! Go to Solution.
09-12-2017 01:56 AM
Yes that one looks ok no sofware defect alert so you should be ok
09-11-2017 08:05 AM - edited 09-11-2017 08:06 AM
Check its corectly saved in startup with below to see if config saved
#more nvram:startup-config
check your config register is set to 2102
also have you tried a newer image thats very old you may be hitting a bug
09-11-2017 08:28 AM - edited 09-11-2017 08:30 AM
Hi Mark,
I have checked the mentioned things , the same is saving in the NVRAM as well the conf reg val is proper it is 0x2102 only.Kindly help me to know which version i can go for upgradation as the cisco suggested version is not available .The " cisco2811" i s unde EOL and EOS..
Kindly suggest on above.
09-11-2017 08:33 AM
You can still download the images online it is EOL alright but there still up there link below on the site to download.
i would go for a v15 but you may need a DRAM increase depending what your hardware has as the older 2811 images only required 256/64 / newer images require 512/128
09-11-2017 09:32 AM
Hi Marks,
The suggested 15.1.4M4 which is having software advisary.Kindly let me know the stayable version.
09-11-2017 09:34 AM
Your just going to have to check them , there EOL whats there is what you have choice with Cisco are not making anymore , i dont have any 2811s there to test , end of life so i cant have them in operation
If there all software advisory you will just have to take a chance , thats the problem with having equipment software out of support
09-11-2017 10:03 AM
Hi Mark,
Kindly let me know "c2800nm-advsecurityk9-mz.151-4.M10.bin" is it stayable version.Even this version is having same DRAM/FLASH space which is meeting my requirement.
Please suggest on the above.
09-12-2017 01:56 AM
