04-25-2016 02:58 AM - edited 03-08-2019 05:29 AM
Hi.. I have been running nexus 9396PX-n9000-dk9.6.1.2.I3.4a.bin. I want to configure IPSLA and track on this device but unable to configure it.
Does this device support IPSLA.
CoreSW(config)# feature ?
bash-shell Enable/Disable bash-shell
bfd Bfd
bgp Enable/Disable Border Gateway Protocol (BGP)
dhcp Enable/Disable DHCP Manager
eigrp Enable/Disable Enhanced Interior Gateway Routing Protocol (EIGRP)
evmed Enable/Disable Generic event detectors
hsrp Enable/Disable Hot Standby Router Protocol (HSRP)
interface-vlan Enable/Disable interface vlan
isis Enable/Disable IS-IS Unicast Routing Protocol (IS-IS)
lacp Enable/Disable LACP
ldap Enable/Disable ldap
lldp Enable/Disable LLDP
msdp Enable/Disable Multicast Source Discovery Protocol (MSDP)
ntp Enable/Disable NTP
nv Enable/Disable VxLAN
nxapi Enable/Disable nxapi
ospf Enable/Disable Open Shortest Path First Protocol (OSPF)
ospfv3 Enable/Disable Open Shortest Path First Version 3 Protocol (OSPFv3)
password Credential(s) for the user(s)/device(s)
pbr Enable/Disable Policy Based Routing(PBR)
pim Enable/Disable Protocol Independent Multicast (PIM)
private-vlan Enable/Disable private-vlan
privilege Enable/Disable IOS type privilege level support
rip Enable/Disable Routing Information Protocol (RIP)
scheduler Enable/Disable scheduler
scp-server Enable/Disable SCP server
sftp-server Enable/Disable SFTP server
ssh Enable/Disable ssh
tacacs+ Enable/Disable tacacs+
telnet Enable/Disable telnet
tunnel Enable/Disable Tunnel Manager
udld Enable/Disable UDLD
vmtracker Enable/Disable VM Tracker feature
vn-segment-vlan-based Enable/Disable VLAN based VN segment
vpc Enable/Disable VPC (Virtual Port Channel)
vrrp Enable/Disable Virtual Router Redundancy Protocol (VRRP)
vtp Enable/Disable VTP
CoreSW(config)# ip ?
access-list Configure access list
adjacency Configure Adjmgr
adjmgr AM information
arp Configure ARP parameters
as-path BGP autonomous system path filter
auto-discard Auto 0.0.0.0/0 discard route
community-list Add a community list entry
dhcp Configure DHCP snooping or relay
dns Configure dns client
domain-list Add additional domain names
domain-lookup Enable/Disable DNS
domain-name Specify default domain name
extcommunity-list Add a extcommunity list entry
ftp Configure FTP client
host Add an entry to the ip hostname table
http Configure HTTP client
icmp-errors ICMP unreachable/TTL-exceeded/param-prob messages
igmp IGMP global configuration commands
internal Show internal information
load-sharing ECMP load-sharing
mfwd Configures Global IP Multicast Forwarding
mroute Configure multicast RPF static route
multicast Configure IP multicast global parameters
name-server Specify nameserver address
prefix-list Build a prefix list
radius Radius server
route Route information
routing Routing information
source Configure source-address for applications
source-route IP source routing option
tcp Global TCP parameters
telnet Configure telnet
tftp Configure TFTP client
traceroute Configure traceroute client
Solved! Go to Solution.
04-25-2016 04:28 AM
Its is supported from v7 as below should be feature sla available are on v6
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/ip_sla/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_IP_SLAs_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_IP_SLAs_Configuration_Guide_7x_chapter_010.html
This chapter provides release-specific information for each new and changed feature in the Cisco Nexus 9000 Series NX-OS IP SLAs Configuration Guide.
Feature |
Description |
Changed in Release |
Where Documented |
IP SLA support |
Initial support |
7.0(3)I2(1) |
04-25-2016 04:28 AM
Feature |
Description |
Where Documented |
IP SLA support |
Initial support |
7.0(3)I2(1) |
01-16-2018 08:24 AM
Hi, I have version NXOS: version 7.0(3)I7(1) and the feature is not there yet!
Software
BIOS: version 07.59
BIOS compile time: 08/26/2016
NXOS image file is: bootflash:///nxos.7.0.3.I7.1.bin
NXOS compile time: 8/31/2017 14:00:00 [08/31/2017 18:29:32]
Hardware
cisco Nexus9000 C9236C chassis
Intel(R) Xeon(R) CPU @ 1.80GHz with 16400580 kB of memory.
is there something that I need to activate?
thanks,
Marc
