IPv4 PBR can not work on on Nexus 3548P switch.
DuJin0509
Hello everyone,
        Could IPv4 PBR feature deploly on Nexus 3548P switch ? I configured PBR feature on my 3548P switch , but it did not work as expect as on IOS platform  , the configuration present to you as follow, the special packet flows can not send to the defined next hop ip address as be set in the route-map noatm , it still used the routing table next hop ip address . How to resolve this problem please ?
         I am looking forward hearing from you , thank you .
!Command: show running-config
!Time: Thu Mar 12 03:42:21 2015
version 6.0(2)A6(1)
hostname N3k-1
feature telnet
feature scp-server
cfs eth distribute
feature ospf
feature pbr
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature lldp
hardware profile tcam region nat 0
hardware profile tcam region pbr 256
ip policy match router-address
route-map noatm pbr-statistics
route-map noatm permit 10
  match ip address noatm
  set ip next-hop 12.1.1.2
nterface Vlan30
  no shutdown
  ip address 10.7.30.11/24
  ip policy route-map noatm
  hsrp 30
    priority 105 forwarding-threshold lower 1 upper 105
    ip 10.7.30.254
    track 1
interface Ethernet1/47
  switchport mode trunk
  switchport trunk allowed vlan 30,100
  channel-group 30 mode active
  no shutdown
interface Ethernet1/48
  no shutdown
interface mgmt0
  vrf member management
  ip address 192.168.1.1/24
line console
line vty
boot kickstart bootflash:/n3500-uk9-kickstart.6.0.2.A6.1.bin
boot system bootflash:/n3500-uk9.6.0.2.A6.1.bin
router ospf 200
  router-id 1.1.1.1
  default-information originate
ip access-list match-local-traffic
ip route 0.0.0.0/0 Ethernet1/6 12.1.1.2
logging monitor 7
Baolong Chen
i have the same problem, all Cisco docs are talking about applying PBR on L3 port NOT VLAN SVIs. Need to call them to check, but it's wired even 3750G/E can support PBR, why Nexus can't?
