IPV6 on vlans do not working
pcfreak49
Hi I have a problem I want my vlans from ipv4 ipv6 to configure but that would not work so that each device receives an ipv6 how can you do that?
Reza Sharifi
If your software support it, you can assign IPv6 address to SVIs
see example:
interface Vlan1
ip address 192.168.1.10 255.255.255.0
ipv6 address 2001:1::/64 eui-64
end
okay thanks I did that and how can you ipv6 dhcp pool and an acl?
I just looked at the PC and there is on temporary ipv6 address is that normal?
and how you can configure the access list because I have done but do not have internet? I
