IPV6 Problem
Patrick McHenry
Level 7
Level 7
I posted a question yesterday concerning IPV6 and updated it to "answered" by mistake.
Whenever someone plugs in an Apple or HP device with IPV6 enabled, the VLAN that it is associated comes to a halt. We get some kind of IPV6 broadcast storm. So, for a work-around, we are deploying new devices with IPV6 disabled.
I was wondering if anybody else has had this problem or if anybody has heard of this before and where I might start to trouble-shoot this issue?
Would this access-list work on my 6509's? I would like to try but, don't anywhere to lab it. Could it work on a 3750 for testing with the ipservices image?
access-list 101 permit ip any any
mac access-list extended IPV6
permit any any 0x86dd
vlan access-map BLOCK_IPV6 10
match mac-address IPV6
action drop
match ip address 101 20
action forward
vlan filter BLOCK_IPV6 vlan-list xx
Thanks, Pat.
Giuseppe Larosa
Hello Pat,
you need also to specify an hex mask of 0x0000 after the ethertype see it as a range of possible ethertypes to filter
mac access-list extended ipv6test
permit any any 0x86dd 0x0000
the VACL has to be written in the following way: ( note the space between mac and address instead of '-')
match mac address ipv6test
action drop
vlan access-map BLOCK_IPV6 20
action forward
I tested the above commands on a C7600, but I couldn't perfom a test with traffic
However,
you can even do this in production router if you start by applying it only in a test vlan instead of all vlans of interest
access-list 101 may be omitted in second VACL block
Final note: IPv6 does not use any form of broadcast but it relies heavily on multicast for different functions
Hope to help
Giuseppe
Thanks!
I did try configuring a 3750 a while back with the 0x86dd then a "?" to see what to put next but, wasn't sure what to put. Thanks for clearing that up.
In your response you didn't put the access-list 101 at the beginning. This is needed, correct? Also, is the 0x0000 similiar to any any?
Have you heard of this IPV6 problem before? It makes me wonder if there is some kind of fundamental problem with the core switches.
Hello Pat,
the mask should be 0x0000 and specifies only that ethertype value to be checked using 0x0001 would mean last bit of ethertype can be 0 or 1 like a wildcard
and yes you need to define acl 101 or you will block everything !!
unfortunately no
Hope to help
Giuseppe
Thanks, Giuseppe!!!
