IPX in Campus
MortezaSoltani
In our layer3 campus there are some novell / ipx workstations in different buildings . Because of missing ipx routing capability in 3550 swithes , connection between hosts was losted .
Is there any way to connect these workstations?
7 Replies 7
asanemeterio
Frequent Visitor
Frequent Visitor
If you must use routing protocol the better solution is creta a tunnel interface and send IPX traffic for this tunnel.
what kind of tunnel may i use with 3550 swithes ?
would u please introduce a reference document?
asanemeterio
Frequent Visitor
Frequent Visitor
continue..
Sorry,
see this link, is a good example about how configure
http://www.cisco.com/en/US/partner/tech/tk827/tk369/technologies_configuration_example09186a0080093f70.shtml
agusti
I have guest level access and your mentioned linke are not accessible for me .
may you send the page to my email .
[email protected]
I send an email with this document
agusti
Dear friend
Thanks for your email ,but as i mentioned before, i need ipx connectivity in campus area which contain Cisco 3550 switches , without IPX routing capability . In the document GRE tunnel is maded by two router and IPX routing command.
glen.grant
You might look into fall back bridgeing for the 3550's . The 3550's need the EMI image to support this
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00802cb7c6.html.
