IR829 LTE connection drops
I have a IR829GW-LTE-VZ-AK9 that is having some cell connection drops. It worked fine in one area (Orlando, FL), but is experiencing drops with the exact same configuration in a different area (Franklin, NC). I am using a cell booster to amplify the signal, but I don't think that is the problem. My reason for thinking that is that I also have a Verizon Jetpack Mifi (Novatel) that is in the same place and it has been totally solid. I think there is some that is annoying the VZ network and it is dropping the data call. Here is what the problem looks like when the connection drops: .Nov 23 12:17:41 EST: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now deleted. .Nov 23 12:17:41 EST: %CELLWAN-2-BEARER_DELETED: Instance id=0, Default bearer (bearer_id=255) in Cellular0 is now deleted. .Nov 23 12:17:43 EST: %LINK-5-CHANGED: Interface Cellular0, changed state to reset .Nov 23 12:17:43 EST: %DIALER-6-UNBIND: Interface Ce0 unbound from profile Di1 .Nov 23 12:17:44 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to down .Nov 23 12:17:48 EST: %LINK-3-UPDOWN: Interface Cellular0, changed state to down Then it comes back a few seconds later: .Nov 23 12:17:59 EST: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP .Nov 23 12:17:59 EST: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=6) in Cellular0 is now UP .Nov 23 12:18:01 EST: %LINK-3-UPDOWN: Interface Cellular0, changed state to up .Nov 23 12:18:01 EST: %DIALER-6-BIND: Interface Ce0 bound to profile Di1 .Nov 23 12:18:02 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up In the connection call history, this is what I see over and over again: tcfnc#sh cell 0 conn call Start Time Stop Time Duration Thu Nov 23 12:11:52 2017 Thu Nov 23 12:12:33 2017 41 seconds Call disconnect reason Call end mode = 3GPP Session disconnect reason type = 3GPP specification defined(6) Session disconnect reason = Regular deactivation(36) Thu Nov 23 12:12:51 2017 Thu Nov 23 12:13:35 2017 44 seconds Call disconnect reason Call end mode = 3GPP Session disconnect reason type = 3GPP specification defined(6) Session disconnect reason = Regular deactivation(36) Again, the signal strength looks good. tcfnc#show cell 0 radio Radio power mode = online LTE Rx Channel Number = 5230 LTE Tx Channel Number = 23230 LTE Band = 13 LTE Bandwidth = 10 MHz Current RSSI = -56 dBm Current RSRP = -84 dBm Current RSRQ = -12 dB Current SNR = 7.6 dB Physical Cell Id = 0x121 Number of nearby cells = 2 Idx PCI (Physical Cell Id) -------------------------------- 1 289 2 290 Radio Access Technology(RAT) Preference = AUTO Radio Access Technology(RAT) Selected = LTE Note the strong RSSI. I thought it might be something with the MTU, that hasn't helped. Router config attached.
6 Replies 6
the config looks fine, I can only think of minor things to add (in bold).
interface Cellular0
no ip address
ip nat outside
ip mtu 1400
ip virtual-reassembly in
encapsulation slip
ip tcp adjust-mss 1360
dialer in-band
dialer pool-member 1
dialer-group 1
async mode interactive
routing dynamic
interface Dialer1
ip address negotiated
ip nat outside
ip mtu 1400
zone-member security external
encapsulation slip
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
I had the 'ip mtu 1400' stuff in there earlier, but it didn't seem to make a difference. I can add the 'routing dynamic' line. I understand the routing stuff just fine, but I don't do much on the cellular side so that is a mystery.
Hello
Would it be possible to post:
Show Cellular0 all
res
Paul
Kind Regards
Paul
Here is that. tcfnc#show cell 0 all Hardware Information ==================== Modem Firmware Version = SWI9X15C_05.05.58.01 Modem Firmware built = 2015/03/05 00:02:40 Hardware Version = 1.0 Device Model ID: MC7350 Package Identifier ID: 1102036_9903208_MC7350_05.05.58.01_00_Cisco_005.005_000 International Mobile Subscriber Identity (IMSI) = 311480344177708 International Mobile Equipment Identity (IMEI) = 356732060198841 Integrated Circuit Card ID (ICCID) = 89148000003358918931 Mobile Subscriber Integrated Services Digital Network-Number (MSISDN) = 2392700803 Modem Status = Online Current Modem Temperature = 33 deg C PRI SKU ID = 1102036, PRI version = 005.029_000, Carrier = Verizon OEM PRI version = 05.05 Profile Information ==================== Profile password Encryption level: 7 Profile 1 = INACTIVE ** -------- PDP Type = IPv4v6 Access Point Name (APN) = vzwims Authentication = None Profile 2 = INACTIVE -------- PDP Type = IPv4v6 Access Point Name (APN) = vzwadmin Authentication = None Profile 3 = ACTIVE* -------- PDP Type = IPv4 PDP address = 100.93.39.96 Access Point Name (APN) = vzwinternet Authentication = None Primary DNS address = 198.224.183.135 Secondary DNS address = 198.224.182.135 Profile 4 = INACTIVE -------- PDP Type = IPv4v6 Access Point Name (APN) = vzwapp Authentication = None Profile 5 = INACTIVE -------- PDP Type = IPv4v6 Access Point Name (APN) = vzw800 Authentication = None * - Default profile ** - LTE attach profile Configured default profile for active SIM 0 is profile 1. Data Connection Information =========================== Profile 1, Packet Session Status = INACTIVE Profile 2, Packet Session Status = INACTIVE Profile 3, Packet Session Status = ACTIVE Cellular0: Data Transmitted = 11458 bytes, Received = 9716 bytes IP address = 100.93.39.96 Primary DNS address = 198.224.183.135 Secondary DNS address = 198.224.182.135 Profile 4, Packet Session Status = INACTIVE Profile 5, Packet Session Status = INACTIVE Profile 6, Packet Session Status = INACTIVE Network Information =================== Current System Time = Thu Nov 23 22:32:1 2017 Current Service Status = Normal Current Service = Packet switched Current Roaming Status = Home Network Selection Mode = Automatic Network = 055-224 Mobile Country Code (MCC) = 311 Mobile Network Code (MNC) = 480 Packet switch domain(PS) state = Attached Registration state(EMM) = Registered EMM Sub State = Normal Service Tracking Area Code (TAC) = 38922 Cell ID = 39097857 Negotiated network MTU is 1428 Radio Information ================= Radio power mode = online LTE Rx Channel Number = 5230 LTE Tx Channel Number = 23230 LTE Band = 13 LTE Bandwidth = 10 MHz Current RSSI = -53 dBm Current RSRP = -85 dBm Current RSRQ = -12 dB Current SNR = 4.4 dB Physical Cell Id = 0x121 Number of nearby cells = 1 Idx PCI (Physical Cell Id) -------------------------------- 1 289 Radio Access Technology(RAT) Preference = AUTO Radio Access Technology(RAT) Selected = LTE Modem Security Information ========================== Active SIM = 0 SIM switchover attempts = 0 Card Holder Verification (CHV1) = Disabled SIM Status = OK SIM User Operation Required = None Number of CHV1 Retries remaining = 3 GPS Information ========================== GPS Info ------------- GPS Feature: enabled GPS Port Selected: Dedicated GPS port GPS Status: GPS location cannot be acquired GPS auto tracking status: disabled (Mode is not set) GPS auto tracking config: disabled GPS Mode Configured: not configured/unknown Last Location Fix Error: Not Available [0x0] SMS Information =============== Incoming Message Information ---------------------------- SMS stored in modem = 5 SMS archived since booting up = 0 Total SMS deleted since booting up = 0 Storage records allocated = 25 Storage records used = 5 Number of callbacks triggered by SMS = 0 Number of successful archive since booting up = 0 Number of failed archive since booting up = 0 Outgoing Message Information ---------------------------- Total SMS sent successfully = 0 Total SMS send failure = 0 Number of outgoing SMS pending = 0 Number of successful archive since booting up = 0 Number of failed archive since booting up = 0 Last Outgoing SMS Status = SUCCESS Copy-to-SIM Status = 0x0 Send-to-Network Status = 0x0 Report-Outgoing-Message-Number: Reference Number = 0 Result Code = 0x0 Diag Code = 0x0 0x0 0x0 0x0 0x0 SMS Archive URL = Error Information ================= This command is not supported on this platform. Modem Crashdump Information =========================== WIC type is 00 Cellular0 is MC73xx based Modem crashdump logging: off
Hello
Im not a wireless experienced but....
"Current RSSI = -56 dBm Current RSRP = -84 dBm Current RSRQ = -12 dB Current SNR = 7.6 dB"
The SNR looks very low which surely result in lower data rates and throughput?
res
Paul
res
Paul
Kind Regards
Paul
It turns out the problem wasn't with the signal. Verizon was dropping the call because they didn't like some of the traffic I was sending out. I resolved it by putting an outbound ACL on on the dialer interface. VZ is issuing IP's that are part of the 100.64.0.0/10 private space (Used for communications between a service provider and its subscribers when using a carrier-grade NAT), so that is why I used that source address range in the ACL. ip access-list extended dialer-out permit tcp 100.64.0.0 0.63.255.255 any permit udp 100.64.0.0 0.63.255.255 any permit icmp 100.64.0.0 0.63.255.255 any permit esp 100.64.0.0 0.63.255.255 any deny ip any any log ! interface Dialer1 ip access-group dialer-out out ! Thanks to all for the suggestions.
