IR829 Wireless AP with Internet Connection
julioegb
Hello everyone, I'm in the challenge of configuring a IR829GW, It's was a little hard but I'm finishing.
I already configured the cellular interface(I'm going to use this interface for internet connection using a SIM).
I already configured a DHCP server for the LAN interfaces and NAT to that network segment. If I connect a device to one of the LAN interfaces with a wired connection I would have Internet connectivity.
I finished the confuration of the AP, I can connect clients using WPA encryption, I use this config:
dot11 ssid ALGO_SSID
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 0 this_is_a_password
   exit
ip dhcp excluded-address 192.168.7.1
ip dhcp pool WIRELESS
 network 192.168.7.0 255.255.255.0
 default-router 192.168.7.1
 dns-server 8.8.8.8
interface BVI1
 mac-address 00f6.6318.efae
 ip address 192.168.7.1 255.255.255.0
 no ip route-cache
bridge 1 protocol ieee
bridge 1 route ip
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm tkip
 ssid ALGO_SSID
 antenna gain 0
 packet retries 64 drop-packet
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
But I need help because I don't know why I have to do to have Internet access from the wifi clients.
I can't reach the IP of the interface wlan-ap0 or the network I had int the Giga interfaces from the wifi clients, the Internet isn't reacheable too
Please help me.
Julio Guzmán
here is what the config should look like. Make sure that Vlan 1 and the BVI on the wireless AP are on the same network:
Router
version 15.5
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 20
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829GW-LTE-GA-ZK9 sn FGL19472082
redundancy
controller Cellular 0
lte sim max-retry 0
lte failovertimer 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface GigabitEthernet0
no ip address
shutdown
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Vlan1
ip address 192.168.7.2 255.255.255.0
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip list 1
access-list 1 permit 192.168.7.0 0.0.0.255
control-plane
line con 0
stopbits 1
line 1
stopbits 1
line 2
script dialer lte
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 100000000
txspeed 50000000
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
no exec
rxspeed 100000000
txspeed 50000000
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
end
WiFi AP
version 15.3
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$PwiT$mShklLd6pD1DL8j0Kjh78.
no aaa new-model
no ip source-route
no ip cef
ip dhcp excluded-address 192.168.7.1 192.168.7.2
dns-server 8.8.8.8
dot11 syslog
authentication open
authentication shared
guest-mode
no ipv6 cef
username Cisco password 7 0802455D0A16
bridge irb
no ip address
no ip route-cache
ssid ALGO_SSID
antenna gain 0
station-role root
bridge-group 1
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
bridge-group 1
interface BVI1
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
6 Replies 6
we need to see the rest of the configuration as well. Post the full configuration...
Thanks Georg, the conf. of the IR829 is:
Mobile_Router#sho runn
Building configuration...
Current configuration : 3412 bytes
! Last configuration change at 22:41:53 UTC Tue Jan 2 2018
version 15.6
hostname Mobile_Router
boot-start-marker
boot system flash:ir800-universalk9-mz.SPA.156-3.M
boot-end-marker
no aaa new-model
ethernet lmi ce
ignition off-timer 900
ignition undervoltage threshold 9
no ignition enable
ip dhcp excluded-address 192.168.43.1 192.168.43.6
ip dhcp pool W_DHCP
 network 192.168.43.0 255.255.255.0
 default-router 192.168.43.1
 domain-name Allied.network
 dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
license udi pid IR829GW-LTE-NA-AK9 sn FTX2043Z010
redundancy
 lte sim data-profile 15 attach-profile 15 slot 0
interface Virtual-LPWA1
 no ip address
 no ip address
 switchport access vlan 101
 no ip address
 spanning-tree portfast
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 duplex auto
 speed auto
interface Cellular0
 ip nat outside
 encapsulation slip
 dialer in-band
 dialer idle-timeout 0
 dialer enable-timeout 6
 dialer string lte
 dialer-group 1
 no peer default ip address
 async mode interactive
 routing dynamic
interface Cellular1
 no ip address
 encapsulation slip
interface wlan-ap0
 ip address 192.168.42.1 255.255.255.0
interface Vlan1
 no ip address
interface Vlan101
 ip address 192.168.43.1 255.255.255.0
 ip nat inside
interface Async0
 no ip address
 encapsulation scada
interface Async1
 no ip address
 encapsulation scada
no ip http server
dialer-list 1 protocol ip permit
ipv6 ioam timestamp
access-list 1 permit any
access-list 1 permit 192.168.43.0 0.0.0.255
control-plane
line con 0
 stopbits 1
line 1 2
 stopbits 1
line 3
 script dialer lte
 no exec
 speed 384000
line 4
 no exec
 transport input all
line 8
 no exec
 speed 384000
line 1/3 1/6
 stopbits 1
line vty 0 4
 login
end
The AP config is:
ap#show running-config
Current configuration : 3629 bytes
! Last configuration change at 00:12:12 UTC Mon Mar 1 1993 by cisco
version 15.3
no service pad
hostname ap
enable secret 5 $1$f8R6$LT02mxwz/3dxi5gWEPIOa1
no aaa new-model
no ip source-route
no ip cef
dns-server 8.8.8.8
dot11 syslog
dot11 ssid MY_SSID
authentication open
guest-mode
wpa-psk ascii 7 14361E0705572E1460
no ipv6 cef
username cisco privilege 15 secret 5 $1$t2wv$n/LDtLDTu6AayyuPzau8R/
bridge irb
no ip address
no ip route-cache
ssid MY_SSID
antenna gain 0
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
antenna gain 0
peakdetect
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
privilege level 15
login local
line vty 0 4
login local
transport input all
cns dhcp
end
Router
version 15.5
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
redundancy
lte sim max-retry 0
lte failovertimer 0
no ip address
shutdown
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
interface Cellular1
no ip address
encapsulation slip
interface Vlan1
ip nat inside
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
no ip http server
control-plane
line con 0
stopbits 1
line 1
stopbits 1
line 2
script dialer lte
stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 4
no exec
transport input all
line 8
no exec
rxspeed 100000000
txspeed 50000000
line 1/3 1/6
stopbits 1
line vty 0 4
login
end
WiFi AP
version 15.3
no service pad
hostname ap
no aaa new-model
no ip source-route
no ip cef
dns-server 8.8.8.8
dot11 syslog
authentication open
guest-mode
no ipv6 cef
bridge irb
no ip address
no ip route-cache
ssid ALGO_SSID
antenna gain 0
station-role root
bridge-group 1
no ip address
shutdown
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
bridge-group 1
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Thanks for your help on this week Georg, now the IR829GW is configured. I'm just curious, I want to give IP addresses via DHCP for the Giga interfaces and for the Wireless clients, now I have working that on my IR829 after I configured two DHCP servers, one for the router and other for the AP, is this the right way to do that? I excluded some Ip addresses on the AP but It doesn't work.
DCHP server config on the IR829:
ip dhcp excluded-address 192.168.7.1 192.168.7.5
ip dhcp excluded-address 192.168.7.129 192.168.7.254
ip dhcp pool W_DHCP
 domain-name my_domain.com
 dns-server 8.8.8.8
 default-router 192.168.7.2
DHCP server on the AP module:
ip dhcp excluded-address 192.168.7.1 192.168.7.128
 default-router 192.168.7.3
 dns-server 8.8.8.8
When I connected a device via wireless I obtained IP addresses from 192.168.7.6, the same as when I connected device on the LAN interfaces.
Regards and thanks.
Julio Guzmán
if you want to have a different pool for the wired clients (on the router), add the below to the router module:
ip dhcp excluded-address 192.168.2.1
ip dhcp pool LAN_WIRED
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8 8.8.4.4
interface Vlan 2
ip address 192.168.2.1 255.255.255.0
switchport acccess vlan 2
The 829 should be handling DHCP for both wired and wireless. It makes it easier for configuration, but if you want to have separate DHCP scopes you will have to follow George's example and create a new VLAN and use a different subnets for the WLAN/LAN.
You could even make it seem like the same subnet by using a /25 mask instead of a /24 mask so you could have for example wired clients on 192.168.7.1-127 and wireless clients on 192.168.7.128-254
If you don't mind the wireless and wired clients on the same VLAN just leave the configuration as is as long as it is working for you as expected.
