subnetting
jonk34567
Level 4
Level 4
question is attached below ? what is the answer ?
The answer is 496
Why, The main subnet is 172.16.128.0/23 so you will make subnetting per 8 new subnets, so you will use the following formula:
2^n >= 8 ; where "n" is the bits used to subnetting.
2^3 >= 8
8 >= 8
So How many bits you have to subnetting
32 - CIDR = available bits to subnetting
32 - 23 = 9
So you have 9 bits to make subnetting.
Now you have used 3 (from "n") the current and new subnet mask are:
Current: 255.255.254.0
New: 255.255.255.192
Why? Binary:
Current : 11111111.11111111.11111110.00000000   (9 zeros)
New:      11111111.11111111.11111111.11000000    (using the new 3 bits "n")
Now the block will be:
256 - modified octet
256 - 192 = 64 ; so the block will be increasing 64 by 64 at the fourth octet.
172.16.128.0/26
172.16.128.64/26
172.16.128.128/26
172.16.128.192/26
172.16.129.0/26
172.16.129.64/26
172.16.129.128/26
172.16.128.192/26
The host per network are 64 (64 - 2 (network and broadcast))
Now the total is: 62 x 8 = 496
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
I don't see an attachment.
image is attached now
The answer is 496
2^3 >= 8
8 >= 8
32 - 23 = 9
Why? Binary:
172.16.128.0/26
172.16.128.64/26
172.16.128.128/26
172.16.128.192/26
172.16.129.0/26
172.16.129.64/26
172.16.129.128/26
172.16.128.192/26
Hope it is useful
496
A /23 supports 8 /26s, each /26 supports 62 hosts IPs, so 8 * 62 = 496.
Or a /23 is 512 IPs. 8 subnets will use 2 IPs (network prefix and broadcast), i.e. 16, so 512 - 16 = 496.
