Is C6807 SUP6T mgmt0 an out-of-band interface ?
todd.hsieh
May I ask if SUP6T mgmt0 an out-of-band interface ? How can I set a static/default route providing remote access for mgmt0 ?
Thanks!
Todd
 - Basically you don't need internal-routing on your device (because it is an isolated port) . The only place where you might need routing is on the rest of your switched-intranet (in order to be able to reach the particular ip-address) depending on how it is setup.
 M.
marce1000
 - mgmt0 is usually configured with a separate management VRF  and ip address. Whether you need a static route once it get's a connection on your 'normal network' depends on the reach ability of the designated address for your operator-equipment.
 M.
Hi Marce1000,
Thank you.
So I guess I can config a static route like this way. Am I right ?
(config)#ip route vrf Mgmt-vrf 10.0.0.0 255.255.255.0 mgmt 0
Todd
 M.
