Is Cisco Catalyst 6000 and 4500 supported on EVE-NG
Joe Ank
Hello everybody,
I want to use EVE-NG to test the LABs,
I want to use a Topology (Full mesh connected) composed by Two Catalyst L3 6500 or 4500, to test VSS and MEC and Two Firewalls.
someone has experienced with any sort of these Two Calayst using VSS, if Yes, where can i find the IOS to upload to EVE-NG ?
I have checked the Supported devices on EVE-NG Websites, I found nothing.
Thank you
marce1000
 - I tend to think not, review these info's : https://www.eve-ng.net/index.php/documentation/howtos/  and https://www.eve-ng.net/index.php/documentation/supported-images/
 M.
marce1000, thank you for your reply,
the purpose of this Lab, is to install Two devices support Virtual System Switch (VSS), to test it on Full Mesh Connected Topology.
is there any device exists on supported devices list EVE-NG Website that support VSS Protocol ?
Thank you
 - Chances are slim apparently , only found this reply at bottom of this thread from B : https://community.cisco.com/t5/other-network-architecture/stack-vss-stackwise-virtual-or-none/td-p/3812544/page/2
 M.
