Is ipbasek9 a feature upgrade to ipbase?
jamesross
Looking for an upgrade for our 3750s currently running c3750-ipbase-mz.122-25.SEE1. I keep running into ipbasek9. What's the difference between ipbase and ipbasek9? Is there a cost associated with going to K9?
8 Replies 8
Edison Ortiz
ipbasek9 will give you SSH, SCP and Kerberos support. You can download the image if you have a CCO account with a contract. Legally, you need to inform a Cisco reseller and purchase the upgrade license.
I have a CCO account. Going through the Software Advisor for an updated IPBASE IOS for SEE1 and it keeps giving me an IPBASEK9 version. Wondering if K9 is the default...
Interesting, I don't use Software Advisor for download, just for investigating features on a IOS set.
The latest IPBase for 3750 is c3750-ipbase-mz.122-37.SE1.bin
and I found it by going to
http://www.cisco.com/kobayashi/sw-center/
Switches Software
LAN Switches
IOS Software
I went to the link and chose CAT3750/IPBASE and got c3750-ipbasek9-mz.122-37.SE1.bin. I don't get it.
I don't get that screen, see attached.
The only feature upgrade I can find for the 3750-SMI is advanced IP services and Enhanced Multilayer Upgrade kit. If K9 is the sugguested upgrade then I want to make sure it's legit before I download it.
I don't understand how are you getting to that screen. Very different than mine. Perhaps it has to do with our CCOs (different rights) ?
If you see my screen, you should be able to download 3750 IPBase w/o Crypto.
