Is it possible to add a static route to an CISCO EPC3925
KarlTH
Dear Cisco-Community,
I am trying to add static route for 84.38.112.0/20 (255.255.240.0) to a second router (gateway) 192.168.0.253 but I found no way to add this in web interface of CISCO EPC3925 from my internet service provider. Not even in manual (cisco-epc3925-manual.pdf) is described how to add an static route or how to access the command line interface.
Is it possible to add a static route to an CISCO EPC3925? If yes, how can I do that? (I have full access to CISCO EPC3925)
Thanks in advance for your help,
Karl
Hello
Do you have a USB/RJ45 console cable? if so connect that cable between the console port of the rtr and a laptop/pc then by using a terminal emulation session such as putty you should be able to access the cli on the rtr and add the static route you desire.
Kind Regards
Paul
6 Replies 6
Hello
Kind Regards
Paul
Hello Paul,
thank you for your answer! No, I have not such USB/RJ45 console cable but I will buy one, if I know where to connect it.
Which of this port on my EPC3925 is for the management port?
I thought the USB port, would be the management port but in the manual I read that it is for connecting USB devices.
THANK YOU,
Karl
Hello
Unfortunately it seems this isn’t applicable  - It looks like the only way to access that router is via the GUI.
You say there is no option to add static routes correct?
Administration/management - select static ip ?
Kind Regards
Paul
I did not find any option to add a static route via the web interface (GUI) but maybe it works with this:
I will check it and come back to you tomorrow!
Thank you in the meantime,
Karl
Hello Paul,
I tried VPN option yesterday but it did not succeed! But I found out that the USB port is a console port and so your first answer is correct. Maybe you have a tip which USB console cable I have to buy.
This one, I can not connect to my laptop because I need two USB type A connectors:
THANKS A MILLION for your help!
Best regards,
Karl
 - FYI : https://www.ebay.com/itm/402315728028?hash=item5dabe2d49c:g:Tg4AAOSw-NFasjxm
 M.
