is it possible to check how much time interface was down?
webstd.design
Just using IOS commands is it possible the above?
Need something like sh ver
Sure you can.  Enter the most basic command "sh int " and look under "Last input".  For example:
GigabitEthernet1/0/8 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0023.ad07.5408
Description:
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 8w2d, output 8w2d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 20
6 Replies 6
SunilKhanna
I guess not, in cli your options are
SW1#sh int gig 0/6 ?
  accounting      Show interface accounting
  capabilities    Show interface capabilities information
  controller      Show interface status, configuration and controller status
  counters        Show interface counters
  crb             Show interface routing/bridging info
  dampening       Show interface dampening info
  debounce        Show interface debounce time info
  description     Show interface description
  etherchannel    Show interface etherchannel information
  fair-queue      Show interface Weighted Fair Queueing (WFQ) info
  flowcontrol     Show interface flowcontrol information
  irb             Show interface routing/bridging info
  mac-accounting  Show interface MAC accounting info
  mpls-exp        Show interface MPLS experimental accounting info
  mtu             Show interface mtu
  precedence      Show interface precedence accounting info
  private-vlan    Show interface private vlan information
  pruning         Show interface trunk VTP pruning information
  random-detect   Show interface Weighted Random Early Detection (WRED) info
  rate-limit      Show interface rate-limit info
  stats           Show interface packets & octets, in & out, by switching path
  status          Show interface line status
  summary         Show interface summary
  switchport      Show interface switchport information
  transceiver     Show interface transceiver
  trunk           Show interface trunk information
  vlan            Show interface vlan information
  |               Output modifiers
Sunil
Pls rate the post, if you find the content useful.
Regards, Sunil Khanna
Someone said me that it's possible
Not through ios i believe, one can check the log timestamp.
SW1(config)#int gig 0/12
SW1(config-if)#sh
SW1(config-if)#
*Mar  2 15:29:02.626: %LINK-5-CHANGED: Interface GigabitEthernet0/12, changed state to administratively down
SW1(config-if)#no sh
SW1(config-if)#
*Mar  2 15:30:11.916: %LINK-3-UPDOWN: Interface GigabitEthernet0/12, changed state to down
Sunil
Description:
Thank you all, but I wanted to know how long WAS interface down and not IS down
Ahhhh ... You want the downtime of the interface?  Then "sh logs" will do (hoping you have enough buffer to capture the time the interface went down).
