Is it possible to connect a switch with ospf to another switch with ospf which is connect to the ABR?
I'm trying to setup multi-area OSPF on our network to reduce the routing tables by summarising routes at the ABRs.
The problem I've got is I have a switch that is connected to another switch which then connects to the ABR.
When I put the two switches in Area 1 and the ABR in Area 1 and 0 I keep getting a message on the middle switch that says: "%OSPF-4-ERRRCV: Received invalid packet: mismatch area ID, from backbone area must be virtual-link but not found from 10.204.255.253, Vlan409"
I don't know why it's receiving invalid packets when both switches have the network 10.204.0.0 0.0.255.255 area 1 command installed.
I have attached a diagram in case my explanation is hard to understand.
11 Replies 11
Jon Marshall
It should be perfectly possible.
Are these the only connections between the devices that your diagram shows ?
Can you post the switch configurations ?
Jon
Here are the configs (minus the ports that are shutdown to save space)
ABR:
Current configuration : 2308 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip routing
spanning-tree mode pvst
interface Loopback0
 ip address 10.200.250.253 255.255.255.0
interface FastEthernet0/1
interface FastEthernet0/2
 switchport trunk native vlan 990
 switchport trunk allowed vlan 1,8,410
 switchport mode trunk
interface FastEthernet0/3
 switchport trunk allowed vlan 1,8,402
interface GigabitEthernet0/1
 switchport trunk allowed vlan 1,8,408
interface GigabitEthernet0/2
 switchport trunk allowed vlan 1,8,401
interface Vlan1
 no ip address
 shutdown
interface Vlan401
 ip address 10.200.255.249 255.255.255.252
interface Vlan402
 ip address 10.200.255.246 255.255.255.252
interface Vlan408
 ip address 10.201.255.253 255.255.255.252
interface Vlan410
 ip address 10.204.255.250 255.255.255.252
router ospf 10
 log-adjacency-changes
 area 0 range 10.200.0.0 255.255.0.0
 area 0 range 10.201.0.0 255.255.0.0
 area 0 range 10.202.0.0 255.255.0.0
 area 0 range 10.203.0.0 255.255.0.0
 network 10.200.0.0 0.0.255.255 area 0
 network 10.1.0.0 0.0.255.255 area 0
 network 192.168.12.0 0.0.3.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
Middle Switch:
Current configuration : 1761 bytes
version 12.2
hostname Switch
ip routing
interface Loopback0
 ip address 10.204.250.253 255.255.255.0
 switchport trunk allowed vlan 1,8,409
interface Vlan1
 no ip address
 shutdown
interface Vlan409
 ip address 10.204.255.253 255.255.255.252
interface Vlan410
 ip address 10.204.255.249 255.255.255.252
router ospf 10
 passive-interface default
 no passive-interface Vlan409
 no passive-interface Vlan410
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
End Switch:
Current configuration : 2360 bytes
version 12.2
hostname Switch
ip routing
interface Loopback0
 ip address 10.204.250.254 255.255.255.0
interface Port-channel 1
 switchport trunk allowed vlan 1,8,400-402,999
 channel-group 1 mode on
interface Vlan1
 no ip address
 shutdown
interface Vlan400
 ip address 10.204.40.1 255.255.255.0
 ip helper-address 10.1.16.12
interface Vlan401
 ip address 10.204.41.1 255.255.255.0
interface Vlan402
 ip address 10.204.42.1 255.255.255.0
interface Vlan409
 ip address 10.204.255.254 255.255.255.252
interface Vlan999
 ip address 10.204.253.1 255.255.255.0
router ospf 10
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
Actually forget that, it doesn't matter.
The configs look okay at the moment.
Have you done a debug on the middle switch to see what the actual LSA being received is ?
Jon
This is the debug from the middle switch:
03:12:44: OSPF: Rcv hello from 10.200.250.253 area 1 from Vlan410 10.204.255.250
03:12:44: OSPF: End of hello processing
03:12:44: OSPF: Rcv hello from 10.204.250.254 area 1 from Vlan409 10.204.255.254
03:12:45: %OSPF-4-ERRRCV: Received invalid packet: mismatch area ID, from backbone area must be virtual-link but not found from 10.204.255.253, Vlan409
I'm not 100% sure how to interpret it.
Interestingly the routes are being distributed properly I'm just getting the error repeatedly so it doesn't seem to be affecting OSPF actually working but I'd still like to get to the bottom of it.
It's the end switch that the middle switch is complaining about.
Can you post a "sh ip ospf database" from the end switch.
Also is the end switch only connected to the middle switch ?
Jon
The end switch has a layer 2 edge switch attached to it that doesn't have OSPF setup on it, I have made all the interfaces other that those involved in OSPF passive.
Here is the database:
            OSPF Router with ID (10.204.250.254) (Process ID 10)
Router Link States (Area 1)
Link ID ADV Router Age Seq# Checksum Link count
10.204.250.254 10.204.250.254 1671 0x80000008 0x0015f0 6
10.200.250.253 10.200.250.253 1542 0x8000000e 0x00fe0d 1
10.204.250.253 10.204.250.253 1541 0x80000010 0x00ea7d 3
Net Link States (Area 1)
10.204.255.254 10.204.250.254 1671 0x80000002 0x0040b3
10.204.255.250 10.200.250.253 1542 0x80000004 0x000316
Summary Net Link States (Area 1)
10.200.0.0 10.200.250.253 1602 0x80000611 0x0004a5
10.1.0.0 10.200.250.253 1552 0x80000632 0x002926
192.168.12.0 10.200.250.253 1552 0x80000633 0x007076
10.203.0.0 10.200.250.253 1552 0x80000634 0x00a3de
10.202.0.0 10.200.250.253 1552 0x80000635 0x00b7c9
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
0.0.0.0 10.200.250.254 1612 0x80000007 0x009a65 1
Peter
Okay that is weird then because the middle switch is definitely complaining about receiving an LSA from the end switch for the wrong area but the middle switch only has one L3 SVI peering with the end switch and that is in area 1.
And the end switch only has LSAs in area 1.
I did wonder if you had somehow created a sort of loop back to the backbone area but if there is one I can't see it.
I'll have another look at the configs and maybe even lab it up but I can't see an obvious issue at the moment.
Jon
Thanks Jon your help is massively appreciated.
I found the answer but a bit of pure luck.
The reason for the error was because it was receiving packet for 10.1.0.0 255.255.0.0 because the 10.1 network is extended out across all the sites
But because 10.1.0.0 0.0.255.255 was in the core switch in area 0 it kept complaining that it was receiving the packet in the wrong area.
Thanks for all your help.
Hi Peter
Thanks for letting me know the resolution.
Jon
Is the end switch connected to any other L3 device ?
Can you post "sh ip ospf database" from the end switch.
Jon
