Is it possible to create a mixed 3750 switch stack with crytographic (k9) and not cryptographic images?
martinezaw
I am trying to add a 3750x to a stack. It is a mixed stack and all the members only use non-cryptographic IPBASE images.
Switch   Ports  Model              SW Version              SW Image
     1   52     WS-C3750G-48TS     12.2(35)SE5             C3750-IPBASE-M
     2   52     WS-C3750G-48TS     12.2(35)SE5             C3750-IPBASE-M
*    3   30     WS-C3750E-24PD     12.2(35)SE5             C3750E-UNIVERSAL-M
I am trying to add the below
WS-C3750X-48P      12.2(55)SE10           C3750E-IPBASEK9-M
As you can see the 3750x I am trying to add has the IPBASEK9 image. Does anyone have a mixed cryptographic/non-cryptographic image environment.
These will not stack. The stack does not even seem to recognize the switch is there at all or gives version mismatch.
Is there a way I can downgrade the IPBASEK9 to just IPBASE? I am not in a position to get a K9 license for the other switches.
Thanks!
Hello
As far as I can see , they are not compatible to stack , Looks like only universal and ipbasek9 ios available for the WS-C3750X-48P
3750 software
Kind Regards
Paul
nixpengu1n
Stack feature is a model-based, not software-based. Theoretically it should be possible, however I do not quite understand why. Ideally your stack needs to run same software version to avoid odd functionality.
More information you could find here:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swstack.pdf
In your particular case you can download image from your stack and exchange it on your new stack member and add it to your main stack either through LAN or console (it will be long and painful).
Joseph W. Doherty
My guess would be the issue is stack protocol code in (55)SE10 likely not compatible with (35)SE5. (You can find out more about that in nixpengu1n's second reference.) I believe you can have a K9 image mixed with non K9 images.
As nixpengu1n suggested, you might downgrade your 3750X using your 3750E's IOS. (I believe this is allowed by Cisco's licensing. Ideally, it would be better to upgrade all your units to 55SE10, but unless your units have an active maintenance contract [which might currently be totally unavailable for your older 3750s], that would, I believe, be a license violation.)
