is it possible to enable to VSS with 6500 chassis when only one chassis have the WISM ?
msangiliraj
Leo Laohoo
Yes.
thank you very much for the reply, that mean both the chassis no need to have the same modules installed on both the chassis .
That is correct.
Adnan Mohammed
Yes, you can.
