Is it possible to know FEX UPLINK port via CLI?
YagBaca95622
Is it possible to see the FEX uplink port via the CLI? (No physical access to the device, For documentation purposes).
For example, we have an Nexus 5 or 7K configured to support the N2k.
How can we know the physical port which is connected to the N2k?
 N5/7K (Ethx/x)-------(???)N2K
You can see the fabric port on the parent switch using the following commands:
show interface fex-fabric
show fex [fex#] [detail]
Do we have any commands to show the physical uplink port connected in N2k?
Any kind of help would be appreciated.
Hi try show interface fex fabric or fex-fabric
8 Replies 8
Mark Malone
Show fex 101 detail should show it as an example ,at the bottom usually its the assigned ports for the uplink
Hi Mark,
Thank you for responding.
I tried that before or am I missing something?
Show fex [FEX NUMBER] details shows only the control port plus the vPC of the parent switch and the FEX's interfaces.
What we are looking is the uplink port of the 2k.
Here is an example of the said command:
NEXUS-5K-SWITCH# show fex 101 detail
FEX: 101 Description: RACKSOMETHINGSOMETHING state: Online
FEX version: 7.1(4)N1(1) [Switch version: 7.1(4)N1(1)]
FEX Interim version: 7.1(4)N1(1)
Switch Interim version: 7.1(4)N1(1)
Extender Serial: FOCSNNUM101010
Extender Model: N2K-C2348TQ-10GE, Part No: 73-16842-04
Card Id: 266, Mac Addr: 50:1d:b5:f6:ed:33, Num Macs: 64
Module Sw Gen: 21 [Switch Sw Gen: 21]
post level: complete
Pinning-mode: static Max-links: 1
Fabric port for control traffic: Eth1/3
FCoE Admin: false
FCoE Oper: true
FCoE FEX AA Configured: false
Fabric interface state:
Po101 - Interface Up. State: Active
Eth1/3 - Interface Up. State: Active
Fex Port State Fabric Port
Eth101/1/1 Up Po101
Eth101/1/2 Up Po101
Eth101/1/3 Up Po101
Eth101/1/4 Up Po101
Eth101/1/5 Up Po101
Eth101/1/6 Up Po101
Eth101/1/7 Up Po101
Eth101/1/8 Up Po101
Eth101/1/9 Up Po101
Eth101/1/10 Up Po101
Eth101/1/11 Up Po101
Eth101/1/12 Up Po101
Eth101/1/13 Up Po101
Eth101/1/14 Up Po101
Eth101/1/15 Up Po101
Eth101/1/16 Up Po101
Eth101/1/17 Up Po101
Eth101/1/18 Up Po101
Eth101/1/19 Up Po101
Eth101/1/20 Up Po101
Eth101/1/21 Up Po101
Eth101/1/22 Down Po101
Eth101/1/23 Down Po101
Eth101/1/24 Down Po101
Eth101/1/25 Down Po101
Eth101/1/26 Down Po101
Eth101/1/27 Down Po101
Eth101/1/28 Down Po101
Eth101/1/29 Down Po101
Eth101/1/30 Down Po101
Eth101/1/31 Down Po101
Eth101/1/32 Down Po101
Eth101/1/33 Down Po101
Eth101/1/34 Down Po101
Eth101/1/35 Down Po101
Eth101/1/36 Down Po101
Eth101/1/37 Down Po101
Eth101/1/38 Down Po101
Eth101/1/39 Down Po101
Eth101/1/40 Down Po101
Eth101/1/41 Down Po101
Eth101/1/42 Down Po101
Eth101/1/43 Down Po101
Eth101/1/44 Down Po101
Eth101/1/45 Down Po101
Eth101/1/46 Down Po101
Eth101/1/47 Down Po101
Eth101/1/48 Down Po101
So what we know right now is:
NEXUS-5K-SWITCH(Eth1/3)--------(unknown port)N2k-FEX101
        >What we are looking is the uplink port of the 2k.
 Note that FEX_ports do not support switch-connections , only host-mode ports.
 M.
Hi Mark,
Looks like that's the command we are looking for but one more question cam up.
On the N2k-2348TQ there are only 6ports for the uplink:
https://www.cisco.com/c/dam/assets/prod/switches/nexus-2000-series/nexus-2348tq-10ge-fabric-extender-3d-model.html
However, the command output looks like this:
ParentSwitch01# show interface fex-fabric
Fabric Fabric Fex FEX Fex
Fex Port Port State Uplink Model Serial
101 Eth1/1 Active 21 N2K-C2348TQ-10GE FOC2037Q1N2
ParentSwitch02# show interface fex-fabric
101 Eth1/1 Active 17 N2K-C2348TQ-10GE FOC2037Q1N2
How do you interpret the FEX UPLINK ports?
ParentSwitch01: FEX UPLINK: 21
ParentSwitch02: FEX UPLINK: 17
it should show something like this from 1 of my 5ks , the uplink should be a 1 -6 port or are you actually using 21 as an uplink ?
sh interface fex-fabric
112 Eth1/6 Configured 0
--- Eth1/9 Discovered 4 N2K-C2248TP-1GE FOX1831G1GW
118 Eth1/10 Active 2 N2K-C2248TP-1GE FOX1829GANE
110 Eth1/30 Active 2 N2K-C2248TP-1GE FOX1831G1H2
112 Eth1/32 Active 2 N2K-C2248TP-1GE FOX1829GAF4
115 Eth1/35 Active 2 N2K-C2248TP-1GE FOX1827GQHT
116 Eth1/36 Active 2 N2K-C2248TP-1GE FOX1831G1GT
117 Eth1/37 Active 2 N2K-C2248TP-1GE FOX1831G1GW
118 Eth1/38 Active 4 N2K-C2248TP-1GE FOX1829GANE
119 Eth1/39 Active 2 N2K-C2248TP-1GE SSI18140121
140 Eth2/3 Active 2 N2K-B22DELL-P FOC1643R06C
141 Eth2/5 Active 2 N2K-B22DELL-P FOC1648R1CE
101 Eth3/1 Active 3 N2K-C2248TP-1GE SSI16220AYX
101 Eth3/2 Active 4 N2K-C2248TP-1GE SSI16220AYX
102 Eth3/3 Active 3 N2K-C2248TP-1GE SSI162204J2
102 Eth3/4 Active 4 N2K-C2248TP-1GE SSI162204J2
Apparently, no one knows the actual physical layout.
We are trying to document the network from scratch.
Is it possible for this specific switch to exceed the allotted number of uplink ports?
N5K-C5624Q
I also tried to check if this might be a bug but it does not look like it.
Cisco Nexus 6000/5600 Series Switches 7.1(4)N1(1)
Is there any other way to check this?
