Is it possible to run RSTP on switch1 and PVST on switch2 if both switches sre connected back to back?
Answer
5 Replies 5
Rolf Fischer
Level 9
Level 9
The topology in your scenario doesn't have redundancy which could result in a bridging loop, so STP is "out of work".
When you say "RSTP on switch1", do you mean a non-Cisco Switch running standard (single instance) RSTP ?
I posted some information regarding the handling of Cisco proprietary per-VLAN BPDUs of 3rd party swichtes here:
https://supportforums.cisco.com/message/3821096#3821096
Feel free to ask for more details.
Best regards
Rolf
ALIAOF_
Level 6
Level 6
Yes but why would you want to do that ?
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Why?
Well, you might have some antique switches that don't support RSTP.  (I got some in "my" network.)
Or, it might just be temporary while your moving from STP to RSTP.
Yes you can.
Alessio
Angus Bishop
Yes both the protocol are compatible . Reffer the software release notes .
Configuration depends on your scenario .
Even mstp is backward compatible with previous stp versions
Angus
Sent from Cisco Technical Support Android App
