Is it possible to sub-interface a 3750 port channel?
jkeeffe
Level 2
Level 2
I have a 3750 switch running ipservices 12.2(46)SE and cannot create a sub-interface on a port channel - at least not by using the traditional method with a command like:
config t
int port-channel 1.400
Is there another code train I can use that will allow port channel subinterfaces?
I need to carry two subnets up the portchannel, one of which is a VRF-lite subnet.
3 Accepted Solutions
Jerry Ye
I don't believe it is possible. You can configure it with trunk and interface VLAN.
int po xx
switchport trunk encap dot1q
switchport mode trunk
int vlan xxxx
ip vrf forwarding RED
ip address x.x.x.x
HTH,
jerry
andrew.prince
Level 10
Level 10
AFAIK - you cannot do that, the default port-channel numbering range is 1 to 48 with no option for sub-interfaces.
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/scg.html
HTH>
   Just configure the port channel  as a normal "switch" trunk  as others have said . You are trying to configure it as a router on stick and thats not possible on a L3 switch.
Jerry Ye
int po xx
int vlan xxxx
ip address x.x.x.x
HTH,
jerry
andrew.prince
Level 10
Level 10
HTH>
