Is my HSRP,interface track config correct?
CSCO10993123
I am using CISCO861 router.
I cannot set track though I want to succeed priority to 20 lowering standby router when the link of FastEthernet4 interfaces is downed.
Would there be a place I have to change some setting and check it where? .
Is it impossible possibly to carry out the TRACK command in CISCO861 router ? .
CISCO861(config)#int vlan 10
CISCO861(config-if)#standby 10 track fastEthernet 4 20
% Interface may already be tracked via tracking command
Track setting isn't being done, an error message is indicated.
" % Interface may already be tracked via tracking command "
Though this command was tried.
CISCO861(config)#
CISCO861(config-if)#standby 10 track 10 decrement 20
CISCO861(config-if)#exit
CISCO861(config)#
CISCO861(config)#track 10 interface fastethernet 4 line-protocol
% Invalid input detected at '^' marker.
CISCO861(config)#t?
table-map   tacacs-server  template  tftp-server
time-range
CISCO861(config)#
There seems to be no TRACK command in global config mode.
Using IOS
Cisco IOS Software, C860 Software (C860-UNIVERSALK9-M),
Version 12.4(20)T2, RELEASE SOFTWARE (fc4)
CISCO861#show run int vlan 10
interface Vlan10
ip address 192.168.0.12 255.255.255.240
ip inspect to-wan in
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1414
standby 10 ip 192.168.0.14
standby 10 priority 110
standby 10 preempt
CISCO861#sh standby
Vlan10 - Group 10
  State is Active
    2 state changes, last state change 00:44:19
  Virtual IP address is 192.168.0.14
  Active virtual MAC address is 0000.0c07.ac0a
    Local virtual MAC address is 0000.0c07.ac0a (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.664 secs
  Preemption enabled
  Active router is local
  Standby router is 192.168.0.13, priority 100 (expires in 10.896 sec)
  Priority 110 (configured 110)
    Track object 10 (unknown)
  Group name is "hsrp-Vl10-10" (default)
CISCO861#
Regards.
Here is the direct link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta21546
According to the defect details its fixed in 12.4(24)T2.
JayaKrishna
Jayakrishna Mada
Please take a look at this CSCta21546.
JayaKrishna
Hi, JayaKrishna.
I very am sorry,
I looked for CSCta21546, but was not able to find it.
What page should I confirm about CSCta21546? .
JayaKrishna
Hi, JayaKrishna.
Unfortunately.
My Cisco-ID was not able to confirm BugToolKit in lack of a right.
I will tried to the update to 12.4(24)T2.
and,
it was able to set the TRACK command.
Thanks a million.
