Is power supply 3k-X 715W AC hot swappable on Cisco 3750X?
Diego Cairns
Diego
Diego Cairns
Sorry, found the answer http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/installation/guide/3750x_3560x_HIG/HIGFRU.html
The power supply is hot-swappable. In some configurations, such as full PoE+ or power sharing mode, removing a power supply causes powered devices to shut down until the power budget matches the input power of a single power supply. To minimize network interruption, hot swap the power supply under these circumstances:
The switch is connected to an XPS 2200 and sufficient power is available.
The switch is in StackPower mode and sufficient power is available (Catalyst 3750-X only).
The switch is powered by other switches in a power stack, and no active backup is in progress.
For the switch commands for displaying the available power budget, see the Catalyst 3750-X and 3560-X Software Configuration Guide.
