OSPF configuration
ssweehinlew
Level 3
Level 3
I try to setup the simple OSPF connection between 2 switches. The setup was done and the protocol is running. When I do the tracertroute from workstation 172.21.6.1 to the next 2 hop of the IP 172.21.3.1, it cannot reach it. It stop at the gateway 172.21.6.254.
Any items I miss out and does static route need to be added?
SW1(config)#router ospf 1
SW1(config-router)#network 172.21.3.0 0.0.0.255 area 2
SW1(config-router)#network 1.1.1.0 0.0.0.255 area 2
SW1(config-router)#network 10.1.3.0 0.0.0.255 area 2
SW2(config)#router ospf 1
SW2(config-router)#network 172.21.6.0 0.0.0.255 area 2
SW2(config-router)#network 2.2.2.0 0.0.0.255 area 2
SW2(config-router)#network 172.21.3.0 0.0.0.255 area 2
29 Replies 29
Reza Sharifi
You need to have common subnet between the 2 switches in order for the peering to work correctly
lets assume int gi0/1 on switch-1 and gi0/1 on switch-2 are connecting the switches together
You need a config like this for each interface
switch-1
config t
int gi0/1
ip add 172.21.3.1 255.255.255.0
no sh
router ospf 1
network 172.21.3.0 0.0.0.255 area 0
switch-2
config t
int gi0/1
ip add 172.21.3.2 255.255.255.0
no sh
router ospf 1
verify with "sh ip os nei" the switches are neighbors
Let me try it out first.
Hello
Can you ping the neighbour, is so can you do it with  also with a large mtu size specified?
Debug ip ospf adj
res
Paul
Kind Regards
Paul
Please refer to below. I have no problem to ping the interface from both of the switches. Can I know confirm that no static route is required for this setup in order for sw1 to ping to sw2 loopback interface?
Switch#debug ip ospf adj
OSPF adjacency events debugging is on
Switch#
00:04:34: OSPF: Rcv DBD from 2.2.2.2 on Vlan506 seq 0x20BCFF9 opt 0x52 flag 0x7 len 32  mtu 1500 state EXCHANGE
00:04:34: OSPF: Nbr 2.2.2.2 has smaller interface MTU
00:04:34: OSPF: Send DBD to 2.2.2.2 on Vlan506 seq 0x20BCFF9 opt 0x52 flag 0x2 len 52
00:04:38: OSPF: Rcv DBD from 2.2.2.2 on Vlan506 seq 0x20BCFF9 opt 0x52 flag 0x7 len 32  mtu 1500 state EXCHANGE
00:04:38: OSPF: Nbr 2.2.2.2 has smaller interface MTU
00:04:38: OSPF: Send DBD to 2.2.2.2 on Vlan506 seq 0x20BCFF9 opt 0x52 flag 0x2 len 52
00:04:43: OSPF: Rcv DBD from 2.2.2.2 on Vlan506 seq 0x20BCFF9 opt 0x52 flag 0x7 len 32  mtu 1500 state EXCHANGE
00:04:43: OSPF: Nbr 2.2.2.2 has smaller interface MTU
00:04:43: OSPF: Send DBD to 2.2.2.2 on Vlan506 seq 0x20BCFF9 opt 0x52 flag 0x2 len 52
Hello
On the switch interface running ip ospf
int x/x
ip ospf ignore-mtu
res
Paul
Kind Regards
Paul
After i issue the ip ospf mtu-ignore, i do not see the message "00:04:34: OSPF: Nbr 2.2.2.2 has smaller interface MTU" come out from debug log.
I still have one question about it. Does static route is required for this setup in order for sw1 to ping to sw2 loopback interface and vice versa?
Hello
I am a bit confused now as to how your topology is set up, Can you post a  diagram and running config of your switches please
res
Paul
Kind Regards
Paul
The connection is just between 2 switches.
Below configuration indicated the network advertises the route to each other from both switches. Does static route is required?
No, you should not need a static route if OSPF is running and exchanging routes properly.
Are you saying it is not working ?
Jon
Yes. It is not working until I added in the static route. I wonder how come like that..
Can you draw a quick diagram showing the IPs of the switch connections and where the PCs are ?
What do the routing tables look like on each switch ?
Jon
set the mtu back to default 1500 (on both routers)
interface xxx
no ip mtu
Please refer to the attached diagram
Please refer to below:
SW1 (Cisco)
Switch#sh ip ospf database
            OSPF Router with ID (1.1.1.1) (Process ID 10)
                Router Link States (Area 2)
Link ID         ADV Router      Age         Seq#       Checksum Link count
1.1.1.1         1.1.1.1         357         0x80000003 0x000D20 3
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
0.0.0.0         1.1.1.1         467         0x80000001 0x00BFE5 10
Switch#sh ip ospf interface brief
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Vl506        10    2               172.21.3.1/24      1     BDR   0/1
Fa0/2        10    2               10.1.3.253/24      1     DR    0/0
Lo0          10    2               1.1.1.1/32         1     LOOP  0/0
Switch#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
2.2.2.2         128   EXCHANGE/DR     00:00:39    172.21.3.2      Vlan506
Switch#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
C       1.1.1.1 is directly connected, Loopback0
     2.0.0.0/32 is subnetted, 1 subnets
S       2.2.2.2 [1/0] via 172.21.3.2
     172.21.0.0/24 is subnetted, 1 subnets
C       172.21.3.0 is directly connected, Vlan506
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.3.0 is directly connected, FastEthernet0/2
Sw2 (Juniper)
root> show ospf database
    OSPF database, Area 0.0.0.2
 Type       ID               Adv Rtr           Seq      Age  Opt  Cksum  Len
Router  *2.2.2.2          2.2.2.2          0x80000008   838  0x22 0xb896  72
root> show ospf interface
Interface           State   Area            DR ID           BDR ID          Nbrs
lo0.0               DR      0.0.0.2         2.2.2.2         0.0.0.0            0
vlan.0              DR      0.0.0.2         2.2.2.2         1.1.1.1            1
vlan.702            DR      0.0.0.2         2.2.2.2         0.0.0.0            0
root> show ospf neighbor
Address          Interface              State     ID               Pri  Dead
172.21.3.1       vlan.0                 ExStart   1.1.1.1            1    36
root> show route
inet.0: 8 destinations, 8 routes (8 active, 0 holddown, 0 hidden)
+ = Active Route, - = Last Active, * = Both
2.2.2.0/24         *[Direct/0] 00:16:35
                    > via lo0.0
2.2.2.2/32         *[Local/0] 00:16:35
                      Local via lo0.0
172.21.3.0/24      *[Direct/0] 00:16:29
                    > via vlan.0
172.21.3.2/32      *[Local/0] 00:16:35
                      Local via vlan.0
172.21.6.0/24      *[Direct/0] 00:16:23
                    > via vlan.702
172.21.6.254/32    *[Local/0] 00:16:34
                      Local via vlan.702
224.0.0.5/32       *[OSPF/10] 00:16:40, metric 1
                      MultiRecv
224.0.0.22/32      *[IGMP/0] 00:16:39
                      MultiRecv
Traceroute from user pC
C:\Users\admin>ping 172.21.6.254
Pinging 172.21.6.254 with 32 bytes of data:
Reply from 172.21.6.254: bytes=32 time=1ms TTL=64
Ping statistics for 172.21.6.254:
    Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
Control-C
^C
C:\Users\admin>tracert -d 172.21.3.1
Tracing route to 172.21.3.1 over a maximum of 30 hops
  1     1 ms     3 ms     1 ms  172.21.6.254
  2     *        *
