- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-26-2009 03:11 PM - edited 03-06-2019 05:56 AM
On a 3560 switchport below, my goal is to make this as "full duplex and speed 100". Since the connection is fiber, I don't see how I can get 100Mbps.
When I read the documentation, it is not clear whether "nonegotiate" is related to speed and auto or whether that is actually a way to stop DTP protocol on the interface thus avoiding trunking.
Am I right that I should do command "no negotiate"?
Gi0/26 myswitch connected trunk a-full a-1000 1000BaseLX SF P
myswitch#show run int g0/26
Building configuration...
Current configuration : 158 bytes
interface GigabitEthernet0/26
switchport trunk allowed vlan 2-5
switchport mode trunk
end
Solved! Go to Solution.
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 04:10 PM
Marlon,
You are referring to two different commands.
The speed 'nonegotiate' disables the link-negotiation protocol on the Gigabit Ethernet ports hence it speeds up the port opening process.
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s6.html#wp1017436
The switchport 'nonegotiate' disables the DTP process
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s7.html#wp1012629
HTH,
__
Edison.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-26-2009 04:10 PM
Marlon,
HTH,
__
Edison.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-27-2009 12:00 AM
If you need 100 Mbps on fibre, then you could buy FastEthernet SFP for both ends of the connection.
This ensures that you'll stay at 100 Mbps :-)
