07-07-2020 10:40 PM
Hello Everyone,
So we will be stacking 2 x C9500-40X-A switches (StackWise Virtual). I just wanted to double-check if SFP-H10GB-CU1M is 100% compatible for this setup?
Because, previously our senior engineer suggested to use SFP-10G-SR, but then I realized since it's for Virtual stacking and the switches are just in the same rack on top of each other. Why would we need use SFP-10G-SR, which is normally for distances greater than 200M?
Again, any help will be greatly appreciated!
All the best!
Solved! Go to Solution.
07-07-2020 11:55 PM
M.
07-07-2020 11:55 PM
M.
07-16-2020 06:51 AM
11-06-2023 06:46 PM
FYI, it works... using SFP-H10GB-CU3M for SVL.
