Is SPAN port configuration built to monitor a whole switch?
jeppeqvist
Hello guys
I'm writing because I have observed something strange on one of the 9300 stacked switches. I thought I had found a solution by creating a port channel within the same NIM module instead of spanning across modules. In that case, we experienced no packet loss. We had 4-5 PCs connected with Iperf3 running at almost 1 gigabit for 20 minutes, and the output loss in port channel 98 was minimal. However, when we tried the same on the other switch, there was packet loss even with just a single PC. I simply don't understand this. We're running version 17.06.05 on both switches.
The setup is as follows: 2 sessions with 3 hosts in each—no packet loss in one port channel, but there is in the other. The strange thing is that I've tried replacing the C9300 24T, but the output remains the same. As I mentioned earlier, the monitor session has been set to "rx" since it seems to be the only potential solution based on what I've seen in Wireshark in terms of minimizing the number of packets. The purpose of this task is to monitor all ports, and we can't use 10-gigabit because the Siem devices only support 1 gigabit.
1: Can you confirm that SPAN is not meant to monitor an entire switch but is designed for troubleshooting specific issues?
2: I can see that there are also some tap solutions, but again, I couldn't find anything that supports 24 copper connections at 1 gigabit; the ones I found were for 100 megabit.
Iperf configuration:
UDP-TEST:> iperf3 -c 192.168.40.1 -p 7575 -u -t 1200 -b 1000M
TCP-TEST:> iperf3 -c 192.168.40.1 -p 7575 -P 8 -t 1200 -b 1000M
We also tried with different frame sizes 64-1514 bytes and jumbo frames same issue with switch 2
Switch configuration:
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
        A - formed by Auto LAG
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
98     Po98(SU)        LACP        Te1/1/3(P)      Te1/1/4(P)
99     Po99(SU)        LACP        Te2/1/3(P)      Te2/1/4(P)
98 = Switch 1
99 = Switch 2
Session 1
Type                     : Local Session
Source Ports             :
    RX Only              : Gi1/0/1-24,Te1/1/1-2,Te1/1/5-8
Destination Ports        : Po98
    Encapsulation        : Replicate
          Ingress        : Disabled
Session 2
Source Ports             :
    Rx Only                 : Gi2/0/16-17,Gi2/0/20-21,Gi2/0/23-24
Destination Ports        : Po99
          Ingress        : Disabled
In session 2, which is failing, I have only selected the source ports where we have connected the PC’s and the iperf server.
Here is output drops with two PC’s running
test-switch#show interface po99 | i line|escription|bits|drops
Port-channel99 is up, line protocol is down (monitoring)
  Description: *** Monitor Session  2 IDS  ***
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 871992
  5 minute output rate 247563000 bits/sec, 21816 packets/sec
     0 unknown protocol drops
PC1 - iperf test
[  4]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[  6]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[  8]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[ 10]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[ 12]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[ 14]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[ 16]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[ 18]  70.01-71.01  sec  6.62 MBytes  55.5 Mbits/sec
[SUM]  70.01-71.01  sec  53.0 MBytes   444 Mbits/sec
 PC2
[  4]  70.01-71.01  sec  14.1 MBytes  118 Mbits/sec
[  6]  70.01-71.01  sec  14.0 MBytes  118 Mbits/sec
[  8]  70.01-71.01  sec  14.0 MBytes  118 Mbits/sec
[ 10]  70.01-71.01  sec  14.1 MBytes  114 Mbits/sec
[ 12]  70.01-71.01  sec  13.9 MBytes  118 Mbits/sec
[ 14]  70.01-71.01  sec  14.1 MBytes  118 Mbits/sec
[ 16]  70.01-71.01  sec  14.1 MBytes  118 Mbits/sec
[ 18]  70.01-71.01  sec  14.0 MBytes  118 Mbits/sec
[SUM]  70.01-71.01  sec  53.0 MBytes   939 Mbits/sec
NB: I also tried to change the port channel to use the following algorithm (src-mixed-ip-port) even though the switches only handle layer 2 traffic.. it seems it helped a bit but it is still not good. any suggestions? I have also tried to make a port channel with 4 interfaces in bundle - and I still got packet loss...
So I'm pretty confused....
/Jeppe
6 Replies 6
Mark Elsen
   >... Can you confirm that SPAN is not meant to monitor an entire switch but is designed for troubleshooting specific issues?
  - Indeed usually span sessions and or configuration will mirror one port only to the span port (or specific vlans -e.g.)
    Check some detailed explanations in : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/218111-verify-span-and-erspan-on-catalyst-9000.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thx for your response...
is there a link where Cisco actually explains that SPAN can't be used for monitoring a whole switch? thx in advance
balaji.bandi
SPAN means you replicting the Traffic - so you see all the traffic in sniffer.
if the switch is layer 2 - then expected to use mac based logic.
also check show switch (is the stack ring ok ?)
#show switch stack-ring speed
#show switch stack-bandwidth
and post the config of port-channel and span port config.
BB
jeppeqvist
test-switch#show switch stack-ring speed
Stack Ring Speed : 480G
Stack Ring Configuration: Full
Stack Ring Protocol : StackWise
test-switch#show switch stack-bandwidth
Stack Current
Switch# Role Bandwidth State
*1 Active 480G Ready
2 Standby 480G Ready
I already posted the configuration - if you take a look at this:
Session 1
Source Ports             :
          Ingress        : Disabled
Session 2
Source Ports             :
          Ingress        : Disabled
that is show output , i am looking interface config as suggested
also did you get chance to read the document posted ?
BB
Hello, I've read the document, but I couldn't find anything about limitations. Can you specify where in the document I should look?
monitor session 1 source interface Gi1/0/1 - 24 rx
monitor session 1 source interface Te1/1/1 - 2 , Te1/1/5 - 8 rx
monitor session 1 destination interface Po98 encapsulation replicate
monitor session 2 source interface Gi2/0/16 - 17 , Gi2/0/20 - 21 , Gi2/0/23 - 24
monitor session 2 destination interface Po99 encapsulation replicate
interface TenGigabitEthernet1/1/3
channel-group 98 mode active
description *** Monitor port ***
interface TenGigabitEthernet1/1/4
description *** Monitor Port ***
interface TenGigabitEthernet2/1/3
channel-group 99 mode active
interface TenGigabitEthernet2/1/4
interface Port-channel98
description *** Monitor Session 1 IDS ***
interface Port-channel99
description *** Monitor Session 2 IDS ***
