Is there a difference between "ipbase" and "universal with ipbase license" ??
Hi, folks.
Anybody encountered any differences in these two releases ???
Following setup:
Two Cat WS-C3560E-48PD-S:
First one:
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3560E-48PD     15.0(2)SE             C3560E-IPBASEK9-M
Second one:
*    1 54    WS-C3560E-48PD     15.0(2)SE2            C3560E-UNIVERSALK9-M
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
I have found that the first one doesn't support parts of the "device-sensor" configuration that the second one
has:
switch1(config)#device-sensor ?
  filter-list  Sensor Protocol Filter List Configuration
  filter-spec  Sensor Protocol Filter Spec Configuration
  notify       Options for when to trigger identity update events
switch1(config)#device-sensor accounting
% Invalid input detected at '^' marker.
switch2(config)#device-sensor ?
  accounting   Trigger accounting updates with sensor TLVs/Options
switch2(config)#device-sensor accounting
switch2(config)#
What happens with the device-sensor data on switch1 ??? Is it still sent via radius accounting to the profiling ISEs and therefore will
show up in the ISE identity database ???
Rgs
Frank
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
My understanding, in theory, both IPBase and Universal with an IPBase license should offer the same feature support.  The latter, though, is usually a bigger image as it supports additional features via license activation.
It's interesting you've found a feature that the Universal allows access to, via an IPBase license, that's not in the IPBase image.  Perhaps it's a possible license "bug"?
