is there a way to configure a router to avoid E1's being bottlenecks?
EnriqueFornes
This is a theoretical question is for a college assignment. I want to connect international IP inbound calls to a router in building A, this router will be connected to 4 PSTN E1's (Europe) going to a PABX in building B, that host the ACD and distributes the calls to the contact center agents. Now, if the 120 DS0's (4 E1's) are in use and a new international IP inbound call arrives to the router in building A, he will not find a voice circuit to route the call to the PABX in building B, so it should send a busy tone to the caller. What I'm trying to see is, if the router in building A can place this new call in queue until a PSTN 64 kbps DS0 channel (from the 4 E1's) is available, routing this call through this channel to the PABX in building B in order to reach an agent, and how it should be configured. Hope my question is clearer. Thanks, Kike.
Nathan Spitzer
This is the wrong forum for that question as you are knee-deep in VOIP-land with that question. I would ask this in the IP Telephony forum.
Second, please provide more information, such as:
1) What model Router
2) What IOS level and feature-set
3) What kind of PBX, including model/manufacturer and software revision
Nathan, thanks for your prompt answer. It's a theoretical question is for a college assignment. I have not decided yet which router or PBX should be used, I'm just trying to see if the configuration for a contact center: a broadband FR access going to a router, going to 4 E1's, going to a PBX with ACD, going to a contact center has a bottleneck in the 4 E1's (120 DS0's). I mean, if the 120 voice circuits are in use and a new call arrives, can a router (which one?) put it in queue until a voice channel from the 4E1's is available, routing the new call through this channel to the PBX ACD in order to reach a live agent, or the caller will receive a busy tone (or go to a VM)?
BTW, which is the URL for the IP telephony forum, I didn't find it.
Thanks, Kike.
