Is there a way to quickly remove config from a range of ports?
Andy White
Level 3
Level 3
I am on a 48 port switch and I have shutdown ports 20-40 using the interface range command, now I need remove the lines of config from those ports.  Normally I use the no command but it takes ages as the ports are quite specific, is there a quicker way as I have to do this at another 28 sites!
2 Accepted Solutions
singhaam007
Level 3
Level 3
Hi Andy,
you can use interface default command witch will remove all the config and put the inter face to default mode.
like, default int range
Please do rate if the given information helps
Giuseppe Larosa
Hello Andy,
there is the default command that should restore the default configuration of a port
It should be something like
config t
default interface type x/y
You need to shut the interfaces again as default settings is not shut
Hope to help
Giuseppe
10 Replies 10
singhaam007
Level 3
Level 3
Hi Andy,
Giuseppe Larosa
Hello Andy,
config t
Hope to help
Giuseppe
Brilliant, thanks guys, this we will help loads.
That is one switch done, can you see why this range wont work?
int range FastEthernet 0/1 -4 , fa 0/6 , fa 0/9 , fa 0/13 , fa 0/16-28 , fa 0/33-48 , gig 0/2
It shows there is an issue between fa 0/16-28 , fa 0/33-48
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
There's a limit of 5 parameters per range command.
Disclaimer
Posting
BTW, I believe I've noticed not all devices shut status is impacted by the default interface command.  To be safe, I follow up default command with similar inteface range command to set or unset shut status as required.
Also, on some devices, defaulting an interface will impact other interfaces QoS settings.  (Just some QoS commands; interfaces controlled by same ASIC.)
Peter Paluch
Hello Andy,
You could use the default interface range command - this will literally erase all the ports' configuration back to their default settings. Could this be helpful?
Best regards,
Peter
Hi Andy,
create different macro's with 5 int in each and then default those macros once
Command
Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
define interface-rangemacro_name interface-range
Define the interface-range macro, and save it in NVRAM.
The macro_name is a 32-character maximum character string.
A macro can contain up to five comma-separated interface ranges. You do not need to enter spaces before or after the comma.
Each interface-range must consist of the same port type.
Step 3
interface range macromacro_name
Select the interface range to be configured by using the values saved in the interface-range macro called macro_name.
You can now use the normal configuration commands to apply the configuration to all interfaces in the defined macro.
Step 4
end
Return to privileged EXEC mode.
Step 5
show running-config | include define
Show the defined interface-range macro configuration.
Step 6
copy running-config startup-config
(Optional) Save your entries in the configuration file.
thanks
greg.fuller
Level 5
Level 5
When you use the "default int range" command note that some IOS releases on some devices are picky on syntax for the interface ranges. I always specify them in the format:
fa1/0/1 - 6, fa1/0/9 - 11
My 3550's were the ones that were very finicky on the format they accepted.
Sent from Cisco Technical Support Android App
Adilson Serrão
conf t
default interface range gig1/x-y
