Is there an interface error chart explaining the possible cause of each?
Andy White
Level 3
Level 3
Hello, is there a chart of some sort that explaining all the attributes in the "show interface gig x/x"? command:
     12627282818 packets input, 13956410964813 bytes, 0 no buffer
     Received 75789 broadcasts (75035 multicasts)
     0 watchdog, 75035 multicast, 0 pause input
     11978362642 packets output, 14652129899933 bytes, 0 underruns
I understand that that Runts are frames recieved under 64 bytes, Giants over 1518 bytes, but why?  For example late collisions are normally duplex issues, cable issue or length of cable...
I am just lookig for something so I can do a lookup if I get any of the errors above (runts, giants, throttles, CC, watchdog, babbles, etc)
This table explains them all.
Maybe this page helps with troubleshooting.
If my answer was useful please mark it as helpful.
