04-11-2016 08:24 AM - edited 03-08-2019 05:18 AM
Even if it's not supported.
If possible I would like to do this temporarily until the users get cut-over to 1gb connections.
Than you,
Eric
04-11-2016 01:22 PM
Hi!
You can try this solution, however it is not recommended. Due to potential problems with your device warranty.
(config)# service unsupported-transceiver
Warning: When Cisco determines that a fault or defect can be traced to
the use of third-party transceivers installed by a customer or reseller,
then, at Cisco's discretion, Cisco may withhold support under warranty or
a Cisco support program. In the course of providing support for a Cisco
networking product Cisco may require that the end user install Cisco
transceivers if Cisco determines that removing third-party parts will
assist Cisco in diagnosing the cause of a support issue.
(config)# no errdisable detect cause gbic-invalid
Hope it helps, regards!
JC
04-11-2016 01:46 PM
I recall someone I used to work with using this command for non-Cisco SFP's. But the device supported 100/1000. The WS-X4448-GB-SFP says that it only supports 1gb. Has the command worked on cards that only support 1gb SFP's?
Thank you,
Eric
04-11-2016 03:11 PM
Hi Eric,
I think you will need to source one of the following as the 4448 only supports 1Gig SFPs:-
Classic Fast Ethernet Fiber Line Card
Figure 28 shows the WS-X4248-FE-SFP.
WS-X4248-FE-SFP:
● 48-port 100BASE-X (SFP optional)
● Customers can mix and match 100BASE-X SFP optics on the same line card
● IEEE 802.3, IEEE 802.3ah, IEEE 802.3x flow control
● Enterprise and commercial: fiber-to-the-desktop applications
● Service providers: running point-to-point Fast Ethernet to the home or business (FTTH)
● 48-port IEEE 802.3 100BASE-FX Fast Ethernet
● Distance: 1.2 miles (2 km) over multimode fiber
● Status: green (operational), red (faulty)
● Link: green (operational), red (faulty)
● Service provider: Run point-to-point Fast Ethernet fiber to the home (FTTX)
● Enterprise and commercial: designed for server farms and switch-to-switch applications
Alex
04-18-2016 04:46 AM
I have another 4500 that has the newer gig line card - WS-X4640-CSFP-E, and I was able add a 100mb SFP and it worked. So I thought that if I used the same IOS on the older card (WS-X4448-GB-SFP) it would work, but it will not load the image. It keeps reverting back to the older image. The only difference is the one with newer card is a 4503 and the one with the older card is a 4506.
I have the boot statement in there for the new image. The way the files are displayed on the 4506 look different from the 4503:
4506:
-#- --length-- ---------date/time--------- path
1 27673 Apr 15 2016 12:39:14 +00:00 cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin
2 125276868 Sep 19 2013 14:13:35 +00:00 COPY.bin
3 28210 Mar 27 2015 19:18:45 +00:00 MAR27_config
4 177993372 Apr 13 2016 12:48:07 +00:00 cat4500e-universalk9.SPA.03.06.00.E.152-2.E.bin
475418624 bytes available (303759360 bytes used)
4503:
1 177993372 Aug 27 2015 03:27:58.0000000000 +00:00 cat4500e-universalk9.SPA.03.06.00.E.152-2.E.bin
2 125888512 Aug 26 2015 09:53:55.0000000000 +00:00 cat4500e-universalk9.SPA.03.04.06.SG.151-2.SG6.bin
484982784 bytes available (304316416 bytes used)
